I am trying to use OpenAcc to parallelize my Monte Carlo code and I am trying to run it with a different number of cores but I keep getting the same results. I have attached my code and make file.
Code on Github under MonteCarlo folder and ACC folder: GitHub - rushipatel12/Cisc372Project
Hi prushir,
What do you mean by cores? I’m guessing you’re meaning gangs.
Vector is always implied. If you look at the -Minfo=accel messages, you’ll see that vector(128) is added. Therefore each vector within a gang is using the same seed value. You’ll only get different values across the gang. One suggestion is to set the vector length to 1 by putting vector_length(1) on the parallel loop, but you’ll lose some performance. Alternatively, create a seed per vector.
43, #pragma acc loop gang(gangs), vector(128) /* blockIdx.x threadIdx.x */
