setting different core voltage along with BCT
Hi!
I have designed a custom board using Tegra Tk1 and used memory characterization tool by following the app note to test memories. so, i am getting the full test pass at 204MHZ frequency. Now according to table 3 in app note, there are different voltage levels at different frequencies. So, i can change the frequency by making changes in config file and uploading related BCT file but how can i change voltage levels related to this frequency according to table 3.
Hi, it means to change voltage in generated dvfs table. Also you can refer to the shmoo script in extras\scripts to get more info of how to change voltage. In fact, it is done by changing the output of PMU.
