I’m trying to implement the following C++ function on CUDA Thrust:
v
oid setFragment( vector< Atom * > &vStruct, vector< Fragment * > &vFragment ) {
Fragment *frag;
int n = vStruct.size();
for( int i = 0 ; i < n-2 ; i++ ){
frag = new Fragment();
frag->index[0] = i;
frag->index[1] = i+1;
frag->index[2] = i+2;
vFragment.push_back( frag );
To do so, I created a functor to set indices of each Fragment vector in the following way:
struct setFragment_functor
const int n;
setFragment_functor(int _n) : n(_n) {}
__host__ __device__
void operator() (Fragment *frag) {
frag->index[0] = n;
frag->index[1] = n+1;
frag->index[2] = n+2;
void setFragment( vector< Atom * > &vStruct, vector< Fragment * > &vFragment ) {
thrust::device_vector<Fragment *> d_vFragment(n-2);
thrust::transform( d_vFragment.begin(), d_vFragment.end(), setFragment_functor( thrust::counting_iterator<int>(0) ) );
thrust::copy(d_vFragment.begin(), d_vFragment.end(), vFragment.begin());
However, I’m getting the following errors for the transformation that I applied:
- error: no instance of constructor “setFragment_functor::setFragment_functor” matches the argument list
argument types are: (thrust::counting_iterator<int, thrust::use_default, thrust::use_default, thrust::use_default>) - error: no instance of overloaded function “thrust::transform” matches the argument list
argument types are: (thrust::detail::normal_iterator<thrust::device_ptr<Fragment *>>, thrust::detail::normal_iterator<thrust::device_ptr<Fragment *>>, )
I’m new to CUDA. I will appreciate if someone can help me to implement the C++ function on CUDA.
