Dear all,
I tried to set enableCamInfiniteTimeout=1 and run argus_camera. But it gave me segmentation fault and this
Executing Argus Sample Application (argus_camera)
Argus Version: 0.97.3 (multi-process)
Error generated. /usr/src/jetson_multimedia_api/argus/apps/camera/modules/Dispatcher.cpp, createSession:1411 Failed to create CaptureSession
Error generated. /usr/src/jetson_multimedia_api/argus/apps/camera/modules/Dispatcher.cpp, createSession:1444 (propagating)
Error generated. /usr/src/jetson_multimedia_api/argus/apps/camera/modules/Dispatcher.cpp, maxBurstRequests:1810 (propagating)
Error generated. /usr/src/jetson_multimedia_api/argus/apps/camera/modules/Dispatcher.cpp, createRequest:1507 (propagating)
Error generated. /usr/src/jetson_multimedia_api/argus/apps/camera/modules/tasks/StillCapture.cpp, start:147 (propagating)
Error generated. /usr/src/jetson_multimedia_api/argus/apps/camera/ui/capture/AppModuleCapture.cpp, start:180 (propagating)
Error generated. /usr/src/jetson_multimedia_api/argus/apps/camera/ui/camera/Main.cpp, onModuleChanged:344 (propagating)
Error generated. /usr/src/jetson_multimedia_api/argus/samples/utils/Observed.cpp, registerObserver:62 (propagating)
Error generated. /usr/src/jetson_multimedia_api/argus/apps/camera/ui/camera/Main.cpp, start:282 (propagating)
Error generated. /usr/src/jetson_multimedia_api/argus/apps/camera/ui/common/App.cpp, run:96 (propagating)
Do anyone have any suggestion?
The jetpack version is 4.5
Thanks in advance
