•Hardware Platform (Jetson / GPU) : Nano 2GB Developer Kit
•DeepStream Version : 5.0
•JetPack Version (valid for Jetson only) : 4.4.1
•TensorRT Version : 7.1
•NVIDIA GPU Driver Version (valid for GPU only) : NA
Need to run USB WEBCAM with specific exposure setting/control.
HI,
I am running YOLO V3 to detect a custom object on Nano with deepstream in python.
I am using deepstream-test-1-usbcam to build the flow for USB WEBCAM.
My usb webcam details : LOGITECH 310.
I have the modified the following piece of code.
caps_v4l2src.set_property(‘caps’, Gst.Caps.from_string(“video/x-raw, framerate=30/1”))
caps_vidconvsrc.set_property(‘caps’, Gst.Caps.from_string(“video/x-raw(memory:NVMM)”))
TO :
caps_v4l2src.set_property(‘caps’, Gst.Caps.from_string(“video/x-raw, framerate=(fraction)30/1, auto-exposure=(int)1, exposure-time=(double)166.66999999999999, width=(int)640, height=(int)480”))
Have verified this in the pipeline by the following piece of code :
print(“Exposure Mode :”, caps.get_property(‘caps’).get_structure(0).get_value(‘auto-exposure’))
print(“Exposure Time :”, caps.get_property(‘caps’).get_structure(0).get_value(‘exposure-time’))
print(“Frame Width :”, caps.get_property(‘caps’).get_structure(0).get_value(‘width’))
print(“Frame Height :”, caps.get_property(‘caps’).get_structure(0).get_value(‘height’))
print(“Frame Rate :”, caps.get_property(‘caps’).get_structure(0).get_fraction(‘framerate’))
This results in :
Exposure Mode : 1
Exposure Time : 166.67
Frame Width : 640
Frame Height : 480
Frame Rate : (True, value_numerator=30, value_denominator=1)
The pipeline produces 29 FPS with lights turned on.
When the lights are turned off or camera is covered in such a way to block lights, FPS reduces to 15.
This indicates that EXPOSURE change/setting has not happened in the gstreamer with deepstream.
But i am able to successfully set the exposure setting using opencv in python on the same camera.
Any possible guide on how to control the EXPOSURE, WIDTH, HEIGHT in the pipeline ?
