setting file position in fortran / std preprocessor defs
Hi all,
I recently found that setting the file position indicator using WRITE() and the POS specifier seems to set the position one byte further than fseek() in C would. Basically, the following code would NOT put your file position back to the same location:
inquire(unit=unitNo,pos=filePos)
write(unit=unitNo,pos=filePos)
Is this correct behavior?
The intel compiler behaves like fseek() in this respect. Since I need to port my code between the two compilers, I want to solve this using the preprocessor. Is there a standard PP defition that identifies the PGI compiler? I can’t find it in any manual.
Thanks in advance and best,
Maarten
The Fortran 2003 Standard says in Section 9.5.1.10:
1 If the file is connected for formatted stream access, the file position specified by POS= shall be equal to
2 either 1 (the beginning of the file) or a value previously returned by a POS= specifier in an INQUIRE
3 statement for the file.
Hi Maarten,
No. This appears to be a compiler error when using formatted and unformatted streams. This has been logged as TPR#18246 and is expected to be fixed in the 12.0 release.
Thanks for the report,
Mat
Hi Mat
Thanks! I thought it’d be weird if the inquiring and setting of file position would behave differently.
Before I have version 12.0 I need to find a solution to make my code portable. Is there a standard preprocessor definition that indentifies the PGI compiler?
Best,
Maarten
Maarten,
I have used __PGI in the past to preprocess out bug-inducing code. Try that.
Matt
Thanks! That worked.
Maarten
