Setting Jetson Nano shutter and gain from C/C++ program
We use C/C++ programs to get frames from sensors, connected to Jetson Nano (L4T 32.3.1).
The V4L drivers are non-Nvidia. The code is based on examples from v4l-utils package.
All operations seem to work OK with one exception: we can’t set/get shutter and gain.
Here is an example of our code:
#include <linux/videodev2.h>
#include "tegra-v4l2-camera.h"
int  fd = ...;    // handle of opened video device
static int xioctl(int fh, unsigned long int request, void *arg)
    int r;
    do {
        r = ioctl(fh, request, arg);
    } while (-1 == r && EINTR == errno);
    return r;
int our_code(void)
    struct v4l2_control  ctl;
    memset(&ctl, 0, sizeof(ctl));
    ctl.id = TEGRA_CAMERA_CID_EXPOSURE;
    ctl.value = 10000;
    rc = xioctl(fd, VIDIOC_S_CTRL, &ctl);
    if(rc==-1)
      printf("%s(): xioctl(): VIDIOC_S_CTRL error=%d\n", __func__, rc);
    else
      printf("%s(): xioctl(): OK\n", __func__);
    return rc;
The function our_code() returns always -1.
We remember that in earlier versions of L4T this code worked.
Thank you in advance.
I check with below command without problem.
Could you confirm and check the v4l-utils to figure the root cause.
v4l2-ctl --set-ctrl=gain=32
v4l2-ctl --get-ctrl=gain
