Hey, I’m trying to use some additional controls to tweak the video encoder output on Jetson Xavier. (H265) However, setting some parameters appears to segfault the process. Is there more documentation or more information about using V4L2_CID_MPEG_VIDEOENC_NUM_REFERENCE_FRAMES
or V4L2_CID_MPEG_VIDEOENC_VIRTUALBUFFER_SIZE
struct v4l2_ext_control ctrls[] = {
// Generic controls
{ .id = V4L2_CID_MPEG_VIDEO_BITRATE, .value = bitrate },
{ .id = V4L2_CID_MPEG_VIDEO_BITRATE_PEAK, .value = bitrate * 2},
{ .id = V4L2_CID_MPEG_VIDEO_BITRATE_MODE, .value = V4L2_MPEG_VIDEO_BITRATE_MODE_VBR },
{ .id = V4L2_CID_MPEG_VIDEO_GOP_SIZE, .value = fps },
// NVIDIA Specific controls
{ .id = V4L2_CID_MPEG_VIDEO_H265_PROFILE, .value = V4L2_MPEG_VIDEO_H265_PROFILE_MAIN },
{ .id = V4L2_CID_MPEG_VIDEOENC_NUM_BFRAMES, .value = 0 },
{ .id = V4L2_CID_MPEG_VIDEO_IDR_INTERVAL, .value = fps },
{ .id = V4L2_CID_MPEG_VIDEOENC_INSERT_SPS_PPS_AT_IDR, .value = true },
{ .id = V4L2_CID_MPEG_VIDEOENC_NUM_REFERENCE_FRAMES, .value = 4},
// Causes segfault
//{ .id = V4L2_CID_MPEG_VIDEOENC_VIRTUALBUFFER_SIZE, .value = 2'000'000 },
// Doesn't seem to do anything
//{ .id = V4L2_CID_MPEG_VIDEOENC_H265_LEVEL, .value = V4L2_MPEG_VIDEO_H265_LEVEL_5_0_HIGH_TIER },
// Works, but creates huge files
//{ .id = V4L2_CID_MPEG_VIDEOENC_ENABLE_LOSSLESS, .value = true },
v4l2_ext_controls ctrl_data {};
ctrl_data.ctrl_class = V4L2_CTRL_CLASS_MPEG;
ctrl_data.count = std::size(ctrls);
ctrl_data.controls = ctrls;
checked_v4l2_ioctl(fd, VIDIOC_S_EXT_CTRLS, &ctrl_data);
