• DeepStream Version
• TensorRT Version
Below is the detailed error message after exporting GST-DEBUG=3:
sgie_efficientnet_tlt_config_20.txt (3.4 KB)
In cb_newpad
gstname= video/x-raw
features= <Gst.CapsFeatures object at 0x7f271c14e348 (GstCapsFeatures at 0x1925ca0)>
0:00:04.056881913 8326 0x1927b20 FIXME basesink gstbasesink.c:3145:gst_base_sink_default_event: stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:04.056913228 8326 0x1927b70 FIXME basesink gstbasesink.c:3145:gst_base_sink_default_event: stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:04.064777618 8326 0x1927ad0 FIXME basesink gstbasesink.c:3145:gst_base_sink_default_event: stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:04.124252724 8326 0x1927ad0 WARN v4l2bufferpool gstv4l2bufferpool.c:1066:gst_v4l2_buffer_pool_start:encoder:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:04.211528394 8326 0x7f26b803d0a0 WARN v4l2videodec gstv4l2videodec.c:1673:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:04.211552043 8326 0x7f26b803d0a0 WARN v4l2bufferpool gstv4l2bufferpool.c:1066:gst_v4l2_buffer_pool_start:nvv4l2decoder0:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:04.217329371 8326 0x7f25f43bf0f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1513:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder0:pool:src Driver should never set v4l2_buffer.field to ANY
0:00:04.245040727 8326 0x7f2690003e80 WARN v4l2bufferpool gstv4l2bufferpool.c:1513:gst_v4l2_buffer_pool_dqbuf:encoder:pool:src Driver should never set v4l2_buffer.field to ANY
