So, it took me some time to figure out how to get getActiveTransforms() NOT to return NULL because of how I was setting the flag eENABLE_ACTIVETRANSFORMS.
Here’s what I did in the setup phase of the scene:
//scene initialization stuff
scene = gPhysics->createScene(sceneDesc);
scene->setFlag(PxSceneFlag::eENABLE_ACTIVETRANSFORMS, true);
So here are my questions. Was I doing something wrong? And if not, what is the difference between setting the flag in sceneDesc (PxSceneDesc) and setting it in scene (PxScene)?
This is a bug in PhysX. We shall do our best to fix this in the next release.
In debug and checked configs we test input values to PxScene::setFlag and immediately return with a warning message if any function arguments are illegal. The test for legality in PxScene::setFlag is incorrect, I’m afraid, and this means that the function does nothing at all in checked and debug when you pass in a legal value. If you look at the error stream you should find an error there - “NpScene::setFlag: This flag is not mutable - you can only set it once in PxSceneDesc at startup!”.
It is a simple change to fix this locally. Take a look at the function PxScene::setFlag in NpScene.cpp. You just need to change the legality check to the following code:
PX_CHECK_AND_RETURN(!(flag & (PxU16)( PxSceneFlag::eENABLE_CCD|PxSceneFlag::eDISABLE_CCD_RESWEEP|PxSceneFlag::eADAPTIVE_FORCE|
PxSceneFlag::eENABLE_KINEMATIC_STATIC_PAIRS|PxSceneFlag::eENABLE_KINEMATIC_PAIRS|
PxSceneFlag::eREQUIRE_RW_LOCK|PxSceneFlag::eDISABLE_CONTACT_REPORT_BUFFER_RESIZE|
PxSceneFlag::eENABLE_PCM)),"NpScene::setFlag: This flag is not mutable - you can only set it once in PxSceneDesc at startup!");
