I have a late 2009 MacPro running MacOS 10.6.3. I have two nvidia GPUs, GTX 285 and GT120 (machine default.) I wanted to make the GTX 285 exclusive as I can not run any applications that take more than 10 seconds on that card. I read that on Linux, one needs to use nvidia-smi in background to set the mode. Is there way on MacOS to achieve similar effect?
Any input will be useful.
Rajesh
Device 0: “GeForce GTX 285”
CUDA Driver Version: 3.0
CUDA Runtime Version: 3.0
CUDA Capability Major revision number: 1
CUDA Capability Minor revision number: 3
Total amount of global memory: 1073414144 bytes
Number of multiprocessors: 30
Number of cores: 240
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 16384
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 2147483647 bytes
Texture alignment: 256 bytes
Clock rate: 1.48 GHz
Concurrent copy and execution: Yes
Run time limit on kernels: Yes
Integrated: No
Support host page-locked memory mapping: Yes
Compute mode: Default (multiple host threads can use this device simultaneously)
Device 1: “GeForce GT 120”
CUDA Capability Minor revision number: 1
Total amount of global memory: 536543232 bytes
Number of multiprocessors: 4
Number of cores: 32
Total number of registers available per block: 8192
Warp size: 32
Clock rate: 1.40 GHz
Integrated: No
Support host page-locked memory mapping: No
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 55683, CUDA Runtime Version = 3.0, NumDevs = 2, Device = GeForce GTX 285, Device = GeForce GT 120
PASSED
