Setting the TX2 up with Auvidea J90 carrier board
I recently purchased a J90 carrier board. I’ve been using the TX2 with the NVIDIA developer kit so far.
Jetpack-3.3
L4T-28.2.1
How can I use it with the J90 board? I’ve downloaded the firmware version 1.6 from here: https://auvidea.com/firmware/, but there aren’t any clear instructions on how to use it.
I’m new to development with the Jetson, and sort of lost on how to proceed. Will I have to format all my current data on the Tx2 if I want to use it with a different board (J90)? Or is it just a firmware patch which I add to the current one?
I found the instructions in the firmware zip file. Pasting it here in case anyone else has trouble finding it.
This file explains the installation of the auvidea kernel and dtbs via Jetpack 3.2
NOTE: please replace ~ with the path to the folder
  1. Backup following files from the Jetpack folder
    ~/Jetpack_3.2/64_TX2/Linux_for_Tegra_tx2/p2771-0000.conf.common
    ~/Jetpack_3.2/64_TX2/Linux_for_Tegra_tx2/kernel/kernel_headers.tbz2
    ~/Jetpack_3.2/64_TX2/Linux_for_Tegra_tx2/kernel/kernel_supplements.tbz2
    ~/Jetpack_3.2/64_TX2/Linux_for_Tegra_tx2/kernel/Image
    ~/Jetpack_3.2/64_TX2/Linux_for_Tegra_tx2/kernel/zImage
    ~/Jetpack_3.2/64_TX2/Linux_for_Tegra_tx2/kernel/dtb/tegra186-quill-p3310-1000-a00-00-base.dtb
    ~/Jetpack_3.2/64_TX2/Linux_for_Tegra_tx2/kernel/dtb/tegra186-quill-p3310-1000-a00-00-ucm1.dtb
    ~/Jetpack_3.2/64_TX2/Linux_for_Tegra_tx2/kernel/dtb/tegra186-quill-p3310-1000-a00-00-ucm2.dtb
    ~/Jetpack_3.2/64_TX2/Linux_for_Tegra_tx2/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb
    ~/Jetpack_3.2/64_TX2/Linux_for_Tegra_tx2/kernel/dtb/tegra186-quill-p3310-1000-c03-00-dsi-hdmi-dp.dtb
  2. Use the following commands to copy the necessary files into the Jetpack folder
    cp ~/auvidea_TX2_Jetpack/dtb/* ~/Jetpack_3.2/64_TX2/Linux_for_Tegra_tx2/kernel/dtb/
    cp ~/auvidea_TX2_Jetpack/packages/* ~/Jetpack_3.2/64_TX2/Linux_for_Tegra_tx2/kernel/
    cp ~/auvidea_TX2_Jetpack/p2771-0000.conf.common ~/Jetpack_3.2/64_TX2/Linux_for_Tegra_tx2/
    cp ~/auvidea_TX2_Jetpack/Image ~/Jetpack_3.2/64_TX2/Linux_for_Tegra_tx2/kernel/
    cp ~/auvidea_TX2_Jetpack/zImage ~/Jetpack_3.2/64_TX2/Linux_for_Tegra_tx2/kernel/
  3. Apply changes and flash the TX2
    cd ~/Jetpack_3.2/64_TX2/Linux_for_Tegra_tx2/
    ./apply_binaries.sh
    cd ~/Jetpack_3.2/
    ./JetPack-L4T-3.2-linux-x64_b196.run
  4. Follow the instruction and of the installation
    Select Development Environment
    → Jetson TX2
    when the Jetpack L4T Component Manager opens
    → press “Clear Actions”-Button in the right corner
    → chose “Flash OS Image to Target” under “Target-Jetson TX2” by clicking on “no action” and change it to “install 28.1.0”
    → under “Install on Target” choose the packages like needed, for example “Multimedia API package” if gstreamer is needed
    → when finished press “Next”
    → Accept all
    → follow the instructions until a console window opens
    → follow the instructions in the console(bring the TX2 into recovery mode) and press “ENTER”
    → wait until the flash process has finished and you are prompted to close the console window
    → close the console window and follow the menus in the Jetpack window until it closes.
  5. Using IMU on TX2
    TX1 is using spidev3.0 for the IMU.
    TX2 is using spidev1.0 for the IMU.
    Change SPI device in RTIMULibDemoGL for TX2:
    found in QT creator project at
    */RTIMULib/Sources/RTIMUHal.cpp
    Change line 53 and 54 in file “RTIMUHal.cpp” from
    m_SPIBus = 3;
    m_SPISelect = 0;
    to
    m_SPIBus = 1;
    m_SPISelect = 0;
    Change line 78 in file “RTIMUHal.cpp” from
    sprintf(buf, “/dev/spidev%d.%d”, m_SPIBus, m_SPISelect);
    to
    sprintf(buf, “/dev/spidev1.0”);
  6. Using native CAN on TX2
    1. load kernel modules for CAN:
      sudo modprobe can
      sudo modprobe can_raw
      sudo modprobe mttcan
    2. set up CAN interface:
      sudo ip link set up can0 type can bitrate 1000000
    3. load modules at startup
      • open the file /etc/modules with a text editor(for example vi, nano or gedit)
      • add the kernel modules below the exiting ones(only one per
known issues:
  • It seems that one of the used kernel modules creates two interfaces, which will show up in the Network manager of the Linux system as not managed Ethernet devices. This bug has only be see with Jetpack 3.2. We are currently trying to find out which module cause this and if it can by removed. A similar bug is described here:16.04 - Device not managed after upgrade to ubuntu 16 - Ask Ubuntu
However, these instructions are still for Jetpack 3.2. I will try it with 3.3 and update.
Hi!
Did you succeed in using J90 / Jetson TX2 on a CAN network?
I believe I configured Linux correctly, but I’m not sure if I configured the CAN transceiver correctly. Could you send me the circuit you used to connect the CAN plug of J90 to the CAN network?
Mauricio
Hey,
Sorry for the late response, but we didn’t try the CAN network. What I pasted above was copied from the Auvidea documentation for the J90.
