Dear @SivaRamaKrishnaNV,
it now works. I am now able to ping the target from the host and the other way around.
nvidia@tegra-ubuntu:~$ sudo ifconfig eth0 10.10.10.1 netmask 255.255.255.0
nvidia@tegra-ubuntu:~$ ifconfig
can0: flags=193<UP,RUNNING,NOARP> mtu 16
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 10 (UNSPEC)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 108
can1: flags=193<UP,RUNNING,NOARP> mtu 16
RX packets 1200 bytes 9600 (9.6 KB)
device interrupt 109
enp4s0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 192.168.0.10 netmask 255.255.255.0 broadcast 192.168.0.255
ether 00:04:4b:f6:54:91 txqueuelen 1000 (Ethernet)
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.10.10.1 netmask 255.255.255.0 broadcast 10.10.10.255
inet6 fe80::204:4bff:fef6:548e prefixlen 64 scopeid 0x20<link>
ether 00:04:4b:f6:54:8e txqueuelen 1000 (Ethernet)
RX packets 9131 bytes 655440 (655.4 KB)
RX errors 0 dropped 30 overruns 0 frame 0
TX packets 14502 bytes 1056551 (1.0 MB)
device interrupt 84
eth0:400: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.200 netmask 255.255.255.0 broadcast 192.168.1.255
device interrupt 84
eth0:900: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.1.0.81 netmask 255.255.0.0 broadcast 10.1.255.255
device interrupt 84
eth0.200: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.42.0.28 netmask 255.255.255.0 broadcast 10.42.0.255
RX packets 2134 bytes 165820 (165.8 KB)
TX packets 6344 bytes 420786 (420.7 KB)
hv0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.12.4 netmask 255.255.255.0 broadcast 192.168.12.255
inet6 fe80::886:4cff:fef8:e900 prefixlen 64 scopeid 0x20<link>
ether 0a:86:4c:f8:e9:00 txqueuelen 1000 (Ethernet)
RX packets 4 bytes 292 (292.0 B)
TX packets 68 bytes 7913 (7.9 KB)
device interrupt 20
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 819 bytes 54974 (54.9 KB)
TX packets 819 bytes 54974 (54.9 KB)
However, I am still not able to cross compile the samples onto the target.
Here are the steps I am executing:
dlr-sr-faz-am@dlrsrfazam:~/nvidia_dev/pegasus$ ln -s /usr/local/driveworks-2.2/samples/cmake/ cmake
dlr-sr-faz-am@dlrsrfazam:~/nvidia_dev/pegasus$ ln -s /usr/local/driveworks-2.2/samples/3rdparty/ 3rdparty
dlr-sr-faz-am@dlrsrfazam:~/nvidia_dev/pegasus$ cp -r /usr/local/driveworks-2.2/samples/src/ .
dlr-sr-faz-am@dlrsrfazam:~/nvidia_dev/pegasus$ cp /usr/local/driveworks-2.2/samples/CMakeLists.txt .
dlr-sr-faz-am@dlrsrfazam:~/nvidia_dev/pegasus$ mkdir build-agx
dlr-sr-faz-am@dlrsrfazam:~/nvidia_dev/pegasus$ cd build-agx/
dlr-sr-faz-am@dlrsrfazam:~/nvidia_dev/pegasus/build-agx$ cmake -DCMAKE_BUILD_TYPE=Release -DCMAKE_TOOLCHAIN_FILE=../cmake/Toolchain-V5L.cmake -DVIBRANTE_PDK:STRING=/home/dlr-sr-faz-am/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux -DVIBRANTE_HOST=10.10.10.1 -DVIBRANTE_INSTALL_PATH=/home/nvidia_dev/pegasus -DVIBRANTE_PASSWORD=<password> ..
dlr-sr-faz-am@dlrsrfazam:~/nvidia_dev/pegasus/build-agx$ make -j
dlr-sr-faz-am@dlrsrfazam:~/nvidia_dev/pegasus/build-agx$ make install
dlr-sr-faz-am@dlrsrfazam:~/nvidia_dev/pegasus/build-agx$ make upload
After the make upload command, I get the following error:
make[3]: sshpass: Command not found
CMakeFiles/upload.dir/build.make:57: recipe for target 'CMakeFiles/upload' failed
make[3]: *** [CMakeFiles/upload] Error 127
CMakeFiles/Makefile2:67: recipe for target 'CMakeFiles/upload.dir/all' failed
make[2]: *** [CMakeFiles/upload.dir/all] Error 2
CMakeFiles/Makefile2:74: recipe for target 'CMakeFiles/upload.dir/rule' failed
make[1]: *** [CMakeFiles/upload.dir/rule] Error 2
Makefile:164: recipe for target 'upload' failed
make: *** [upload] Error 2
All the setps seem to work except the make upload
command even though I am able to ping the target from the host.
How can I resolve this problem? Is there something wrong with the peer to peer ethernet connection?
If you need any terminal outputs from the commands I used and mentioned above, please let me know.
