My current goal is to run gpu-burn from a bootable USB stick.
What works right now is to follow the instructions at the CUDA Toolkit 12.8 Downloads site, and install cuda-toolkit-12-8 and nvidia-open. gpu-burn compiles and runs fine, identifies the GPUs correctly - all good.
The problem is that apt-get -y --no-install-recommends install cuda-toolkit-12-8 nvidia-driver-cuda nvidia-open installs over 10GB of files - which is a lot for a USB stick.
Is there a minimal set of packages that I could install without pulling in things that I don’t need, like graphical utilities, profilers, debuggers, etc.?
Good point - I already have the binary from previous runs, and could just copy it to the USB stick.
All I would need is the drivers and any libraries that the executable depends on. Is there a set of Debian packages that does only that? Even the nvidia-open package by itself wants to install Nsight.
I’m not familiar with gpu-burn or the packaging system, but I’d have thought all you need is a driver to suit the range of cards. That should contain all that’s required.
