Setting up error at tensorrt-laboratory
Trying to setup tensorrt-laboratory. I followed the step mentioned in the page. The steps are
git clone http://github.com/nvidia/tensorrt-laboratory
cd tensorrt-laboratory
make
nvidia-docker run --rm -ti tensorrt-laboratory jupyter lab
# navigate to the notebooks folder and open Quickstart.ipynb
But I have error at make.
The error is
ERROR: Command errored out with exit status 1:
     command: /usr/bin/python3 -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-buf7il9j/MarkupSafe/setup.py'"'"'; __file__='"'"'/tmp/pip-install-buf7il9j/MarkupSafe/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-f5gy61v7
         cwd: /tmp/pip-install-buf7il9j/MarkupSafe/
    Complete output (5 lines):
      File "<string>", line 1, in <module>
      File "/tmp/pip-install-buf7il9j/MarkupSafe/setup.py", line 6, in <module>
        from setuptools import setup, Extension, Feature
    ImportError: cannot import name 'Feature'
ERROR: Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
I have setuptools installed version 46.4.0.
Can you try solution suggested in below link:
