Setting Up nvOCDR example on Orin Nano
I am running Jetpack 6.0, Deepstream 6.4 on a Orin Dev Kit and am trying to get the nvOCDR example running using these instructions
I’m running in a nvcr.io/nvidia/deepstream:6.4-triton-multiarch container, used this start command
docker run --runtime nvidia --name testOCR -it --privileged --net=host nvcr.io/nvidia/deepstream:6.4-triton-multiarch bash
and followed all the instructions for a Jetson device, as far as I can tell with no errors
When I run this basic pipeline I get a good udp stream at my receiving PC
GST_DEBUG=3 gst-launch-1.0 \
v4l2src device=/dev/video0 ! video/x-raw, width=1280, height=720, framerate=30/1 ! \
nvvideoconvert ! \
x264enc tune=zerolatency speed-preset=veryfast ! \
h264parse ! rtph264pay config-interval=1 pt=126 ! \
udpsink host=192.168.8.179 port=10101
When I add the nvstreammux and nvmultistreamtiler elements, I get a UDP stream, but its a blank green screen
nvvideoconvert ! \
m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=720 ! \
nvmultistreamtiler rows=1 columns=1 width=1280 height=720 ! nvvideoconvert ! \
And when I try to do the full example pipeline, the pipeline freezes with one CPU maxed out but otherwise nothing seeming to happen on the device
Here is the pipeline
nvvideoconvert ! \
nvdsvideotemplate customlib-name=./libnvocdr_impl.so \
customlib-props="ocdnet-engine-path:./ocdnet.fp16.engine" \
customlib-props="ocdnet-input-shape:1,720,1280" \
customlib-props="ocdnet-binarize-threshold:0.1" \
customlib-props="ocdnet-polygon-threshold:0.3" \
customlib-props="ocdnet-max-candidate:200" \
customlib-props="ocrnet-engine-path:./ocrnet.fp16.engine" \
customlib-props="ocrnet-dict-path:./character_list.txt" \
customlib-props="ocrnet-input-shape:1,32,100" ! \
nvmultistreamtiler rows=1 columns=1 width=1280 height=720 ! nvvideoconvert ! nvdsosd ! nvvideoconvert ! \
And here are the logs
root@ubuntu:~/testFiles# GST_DEBUG=3 gst-launch-1.0 \
nvvideoconvert ! \
Setting pipeline to PAUSED ...
Inside Custom Lib : Setting Prop Key=ocdnet-engine-path Value=./ocdnet.fp16.engine
Inside Custom Lib : Setting Prop Key=ocdnet-input-shape Value=1,720,1280
Inside Custom Lib : Setting Prop Key=ocdnet-binarize-threshold Value=0.1
Inside Custom Lib : Setting Prop Key=ocdnet-polygon-threshold Value=0.3
Inside Custom Lib : Setting Prop Key=ocdnet-max-candidate Value=200
Inside Custom Lib : Setting Prop Key=ocrnet-engine-path Value=./ocrnet.fp16.engine
Inside Custom Lib : Setting Prop Key=ocrnet-dict-path Value=./character_list.txt
Inside Custom Lib : Setting Prop Key=ocrnet-input-shape Value=1,32,100
Pipeline is live and does not need PREROLL ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
Redistribute latency...
0:00:00.980723116   367 0xaaab092c3360 WARN          v4l2bufferpool gstv4l2bufferpool.c:842:gst_v4l2_buffer_pool_start:<v4l2src0:pool0:src> Uncertain or not enough buffers, enabling copy threshold
After a bit of waiting I then get this log, and the pipeline dies
CUDA runtime error an illegal memory access was encountered at line 763 in file nvocdrlib_impl.cpp
I am running this in a directory which contains these files
root@ubuntu:~/test# ls
character_list.txt  libnvocdr_impl.so  ocdnet.fp16.engine  ocrnet.fp16.engine  output.mp4  vid.mp4
Why is it showing a green screen with the deep stream elements and then freezing/dying with the ocr element?
Note: I tried this with Jetpack 5.1.2 and a Deepstream 6.2 container with completely different results (though still not functional). What container / environment was this example supposed to run on?
You can try this sample. It is based on DS-6.4.
Is it supposed to run after following the setup instructions? When I try to run after going through all the steps i get these logs, and the pipeline fails
root@ubuntu:~/deepstream_tao_apps-master/apps/tao_others/deepstream-nvocdr-app# ./deepstream-nvocdr-app nvocdr_app_config.yml
(deepstream-nvocdr-app:538): GStreamer-WARNING **: 19:56:05.814: Trying to link elements nvvid-converter1 and nvvideo-caps that don't share a common ancestor: nvvideo-caps hasn't been added to a bin or pipeline, and nvvid-converter1 is in nvocdr-pipeline
OSD and sink elements link failure.
Im running in the same DS 6.4 container
The error seems to indicate that the bug is in the .cpp demo app. Can someone confirm the app works as is on their system?
If I try to use the gst-launch script from the previous example (but with the libraries from the new example) I get the same logs as I got in my first post. Can someone confirm if they can get the new example working with gst-launch?
Or can anyone confirm if they are able to run either this example
Or this example
Without modifying source code? I cant get them working but I am hesitant to start messing with the code if the examples are working for others.
Have you run it successfully so far?
Have you tried modifying the code or configuration files? You may need to modify the source-list in nvocdr_app_config.yml to your file
source-list:
   #list: file:///workspace/nvocdr/img_0.jpg;file:///workspace/nvocdr/img_1.jpg
   list: file:///workspace/nvocdr/pexels-george-morina-5266796.mp4
I have not been able to get it running. I have modified the configuration file, but have not yet started modifying source code. Are you able to get it running by only modifying configuration files?
Yes, please follow the README. We tested on DS-6.4 and it works fine.
Ok, making some progress
First, the code uses nvv4l2h264enc, but the Orin Nano does not have the hardware decoder, so I switched the output to fakesink (option 2 in the config file)
Now the code seems to be running, but I am getting this error
 Now playing!
Inside Custom Lib : Setting Prop Key=ocdnet-engine-path Value=../../../models/nvocdr/ocdnet.fp16.engine
Inside Custom Lib : Setting Prop Key=ocdnet-input-shape Value=3,736,1280
Inside Custom Lib : Setting Prop Key=ocrnet-engine-path Value=../../../models/nvocdr/ocrnet.fp16.engine
Inside Custom Lib : Setting Prop Key=ocrnet-dict-path Value=character_list.txt
Decodebin child added: source
Decodebin child added: decodebin0
Running...
In cb_newpad
###Decodebin did not pick nvidia decoder plugin.
Error reading serialized TensorRT engine: ../../../models/nvocdr/ocdnet.fp16.engine
terminate called after throwing an instance of 'std::length_error'
  what():  cannot create std::vector larger than max_size()
Aborted (core dumped)
With this config file
source-list:
   list:  file:///home/beauceron/Workspace/deepstream_tao_apps/apps/tao_others/deepstream-nvocdr-app/pexels-george-morina-5266796.mp4
output:
  ## 1:file ouput  2:fake output 3:eglsink output
  type: 2
  ## 0: H264 encoder  1:H265 encoder
  enc: 0
  bitrate: 2000000
  ##The file name without suffix
  filename: test
streammux:
  width: 1280
  height: 720
  batched-push-timeout: 40000
video-template:
  #x86
  #customlib-name: nvocdr_libs/x86/libnvocdr_impl.so
  #aarch64
  customlib-name: nvocdr_libs/aarch64/libnvocdr_impl.so
  customlib-props:
    - ocdnet-engine-path:../../../models/nvocdr/ocdnet.fp16.engine
    - ocdnet-input-shape:3,736,1280
    - ocdnet-binarize-threshold:0.1
    - ocdnet-polygon-threshold:0.3
    - ocdnet-max-candidate:200
    - ocrnet-engine-path:../../../models/nvocdr/ocrnet.fp16.engine
    - ocrnet-dict-path:character_list.txt
    - ocrnet-input-shape:1,32,100
Going back to running in a container, just to make sure the environment is correct.
I ran this command to start the container
docker run -it --net=host --runtime nvidia  -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-6.4 -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/deepstream:6.4-triton-multiarch
I then ran through all the instructions here
And I changed the config file to this (the test.mp4 file exists)
source-list:
   list: file:///root/test.mp4
output:
  type: 2
  enc: 0
  bitrate: 2000000
  filename: test
streammux:
  width: 1280
  height: 720
video-template:
  #x86
  #aarch64
  customlib-props:
And when I run I get this error
root@ubuntu:~/deepstream_tao_apps/apps/tao_others/deepstream-nvocdr-app# ./deepstream-nvocdr-app nvocdr_app_config.yml
nvbufsurftransform: Could not get EGL display connection
 Now playing!
Running...
Decodebin child added: qtdemux0
Decodebin child added: multiqueue0
Decodebin child added: h264parse0
Decodebin child added: capsfilter0
/bin/bash: line 1: lsmod: command not found
/bin/bash: line 1: modprobe: command not found
Decodebin child added: nvv4l2decoder0
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NvMMLiteBlockCreate : Block : BlockType = 261
In cb_newpad
###Decodebin pick nvidia decoder plugin.
nvbufsurface: Could not get EGL display connection
nvbufsurface: Can't get EGL display
ERROR from element nvocdr_template: SetInitParams Error
Error details: SetInitParams Error
Returned, stopping playback
free(): invalid pointer
Why am I getting EGL Display connection errors? I am not using a display, and its set to fakesink, not eglsink output
Small update,
I did get the test.cpp program from the NVIDIA-Optical-Character-Detection-and-Recognition-Solution repo working
But the deepstream example is still not working.
With this pipeline
gst-launch-1.0 filesrc location=test.jpg ! jpegparse ! nvv4l2decoder  ! \
m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=1080 ! \
nvdsvideotemplate customlib-name=./deepstream/libnvocdr_impl.so \
customlib-props="ocdnet-input-shape:3,736,1280" \
nvmultistreamtiler rows=1 columns=1 width=1280 height=720 ! nvvideoconvert ! nvdsosd ! \
nvvideoconvert ! 'video/x-raw,format=I420' ! jpegenc ! jpegparse ! filesink location=output.jpg
I get these errors
Pipeline is PREROLLING ...
NvMMLiteBlockCreate : Block : BlockType = 256
[JPEG Decode] BeginSequence Display WidthxHeight 1118x1063
(gst-launch-1.0:1316): GStreamer-CRITICAL **: 04:14:22.099: gst_caps_set_simple: assertion 'GST_IS_CAPS (caps)' failed
(gst-launch-1.0:1316): GStreamer-Base-CRITICAL **: 04:14:22.099: basetransform: second attempt to fixate caps returned invalid (NULL) caps on pad nvdsvideotemplate0:sink
(gst-launch-1.0:1316): GStreamer-CRITICAL **: 04:14:22.100: gst_caps_set_simple: assertion 'GST_IS_CAPS (caps)' failed
(gst-launch-1.0:1316): GStreamer-Base-CRITICAL **: 04:14:22.100: basetransform: second attempt to fixate caps returned invalid (NULL) caps on pad nvdsvideotemplate0:sink
(gst-launch-1.0:1316): GStreamer-CRITICAL **: 04:14:22.127: gst_caps_set_simple: assertion 'GST_IS_CAPS (caps)' failed
(gst-launch-1.0:1316): GStreamer-Base-CRITICAL **: 04:14:22.127: basetransform: second attempt to fixate caps returned invalid (NULL) caps on pad nvdsvideotemplate0:sink
(gst-launch-1.0:1316): GStreamer-CRITICAL **: 04:14:22.141: gst_caps_set_simple: assertion 'GST_IS_CAPS (caps)' failed
(gst-launch-1.0:1316): GStreamer-Base-CRITICAL **: 04:14:22.141: basetransform: second attempt to fixate caps returned invalid (NULL) caps on pad nvdsvideotemplate0:sink
(gst-launch-1.0:1316): GStreamer-Base-CRITICAL **: 04:14:22.142: basetransform: second attempt to fixate caps returned invalid (NULL) caps on pad nvdsvideotemplate0:sink
nvstreammux: Successfully handled EOS for source_id=0
(gst-launch-1.0:1316): GStreamer-CRITICAL **: 04:14:22.142: gst_caps_set_simple: assertion 'GST_IS_CAPS (caps)' failed
(gst-launch-1.0:1316): GStreamer-CRITICAL **: 04:14:22.143: gst_caps_set_simple: assertion 'GST_IS_CAPS (caps)' failed
(gst-launch-1.0:1316): GStreamer-Base-CRITICAL **: 04:14:22.143: basetransform: second attempt to fixate caps returned invalid (NULL) caps on pad nvdsvideotemplate0:sink
(gst-launch-1.0:1316): GStreamer-CRITICAL **: 04:14:22.144: gst_caps_set_simple: assertion 'GST_IS_CAPS (caps)' failed
(gst-launch-1.0:1316): GStreamer-Base-CRITICAL **: 04:14:22.144: basetransform: second attempt to fixate caps returned invalid (NULL) caps on pad nvdsvideotemplate0:sink
Because some plugins use CUDA and GLES (not eglsink), the device will be initialized.
This error is usually not related to the monitor.
