I have a project setup to use libgnustl_shared.so by specifying -lgnustl_shared as a linker command line argument. However the resulting apk does not contain it. When I add it manually via aapt, I get the error:
Package com.mycompany.myapp has no certificates at entry lib/armeabi-v7a/libgnustl_shared.so; ignoring, which then seems to results in the package not loading.
What is the proper way to specify gnustl_shared?
