Hi, for the jetson NX you can download an SD card image and use SSH to connect to the device via USB using a windows 10 desktop.
Is there a way to do this on the AGX? I need to get it running and setup a remote server, I see a micro-SD card slot but there isn’t any AGX image I can load onto it. Using the instructions in the manual I need to download Ubuntu in order to load the firmware and set the device up which I would prefer to avoid doing.
