You are still required to specify the root block device even with
-r --no-systemimg
If there is an SD card inserted, flash.sh overwrites the GPT on it even with
-r --no-systemimg
If you specify a non-existent root block device and
-r --no-systemimg
, flash.sh completes successfully, but it still overwrites the GPT on the SD card. -
If there’s no SD card inserted in the device, flash.sh hangs.
Thanks for pointing out these. Will check.
Per checked the flash.sh, I think you misunderstood the usage of these parameters.
- The “–no-systemimg” is “Do not create or re-create system.img.”, it didn’t say it will not flash SD, it just suppose you already prepared the systemimg, and will not check if it is exist.
- The “-r” is the re-used the systemimg and the flash.sh will check if the systemimg exist or not.
- The flash.sh flash the device based on the layout xml file, it will flash all partitions in this xml file. Thus, if you specify a board config file that would flash sdcard, then it will flash the sd.
Thus, for your point (1) (2) (3), they have nothing to do with --no-systemimg.
For (4), it hangs because you may choose a board config that requires to flash sdcard.
