Severe performance regression in nvc++ starting from 24.11
I have a code base which uses “expression templates” approach to allow writing mathematical operations for thrust device_vectors with lazy evaluation. The idea is that one can write possibly long mathematical expressions with simple syntax using operator overloading and the kernel is only evaluated when it is fully specified and actually needed. The functionality is based on thrust transform_iterators and zip_iterators.
The performance of the code has been good even with rather complex expressions. However, when I tried to update our system to newer HPC SDK, I noticed severe regressions in performance with the code becoming ~10-100x slower. I managed to pinpoint the slowdown to version 24.11. 24.9 still works ok, but all the versions after that do not. The most recent version 25.7 is a bit better, but still unuseably slow.
Now I don’t know whether this is related to changes in thrust/CCCL or nvc++, but because both 24.9 and 24.11 appear to use the same version of CCCL, I would guess it is related to the compiler. Also, nvcc doesn’t seem to show same issues (at least in a simple test case), only nvc++.
I managed to create a small example, which is given below. This is rather artificial, but it mimics the behaviour of the code that would be produced through operator overloading and expression templates. In pseudo-code an expression like “(vec_a + vec_b) + vec_c” would become
transform
zip
transform
zip(vec_a, vec_b), Sum
vec_c
Sum
and so on.
The example:
#include <thrust/iterator/transform_iterator.h>
#include <thrust/iterator/counting_iterator.h>
#include <thrust/device_vector.h>
#include <thrust/tuple.h>
#include <chrono>
#include <iostream>
// Adaptor for binary expressions
template <typename BinaryOp>
struct ApplyBinaryOp
    BinaryOp op;
    inline __host__ __device__ ApplyBinaryOp(BinaryOp f)
        : op(f) {}
    template <typename Tuple>
    inline __host__ __device__ auto operator()(const Tuple& t) const
        return op(thrust::get<0>(t), thrust::get<1>(t));
// Example operator
struct Sum
    __host__ __device__
    double operator()(double x, double y) const
        return x+y;
int main()
    // Generate some dummy vectors vec_a vec_b
    const size_t N = 100000000;
    thrust::counting_iterator<double> iter(1);
    thrust::device_vector<double> vec_a(N);
    thrust::copy(iter, iter + vec_a.size(), vec_a.begin());
    thrust::device_vector<double> vec_b = vec_a;
    // Create a lazy expression for
    // "(vec_a + vec_b) + (vec_a + vec_b) + vec_b"
    // Create vec_a + vec_b
    auto z1 = thrust::make_zip_iterator(vec_a.begin(), vec_b.begin());
    auto t1 = thrust::make_transform_iterator(z1, ApplyBinaryOp<Sum>(Sum{}));
    // Add another (vec_a + vec_b) by referencing to t1
    auto z2 = thrust::make_zip_iterator(t1, t1);
    auto t2 = thrust::make_transform_iterator(z2, ApplyBinaryOp<Sum>(Sum{}));
    // Finally add vec_b
    auto z3 = thrust::make_zip_iterator(t2, vec_b.begin());
    auto t3 = thrust::make_transform_iterator(z3, ApplyBinaryOp<Sum>(Sum{}));
    // Force evaluation, eg. using thrust::reduce here
    auto start = std::chrono::high_resolution_clock::now();
    double x = thrust::reduce(t3, t3+N, double(0), thrust::plus<double>());
    auto stop = std::chrono::high_resolution_clock::now();
    auto duration = std::chrono::duration_cast<std::chrono::microseconds>(stop - start);
    std::cout << "Result " << x << " took " <<  duration.count() << " us." << std::endl;
If I compile this with "nvc++ -std=c++17 -stdpar -fast " I get following runtimes
24.9: ~3000 us
24.11: ~33300 us
25.7: ~23600 us
ie. 7-10x increase in runtime. While figuring this out, I tried many different O-levels and other flags, but nothing seemed to help.
If you use Nsys, you will see that the issue is related to different number of registers.
Slow case:
Begins: 0.379154s
Ends: 0.399616s (+20.462 ms)
grid: <<<400, 1, 1>>>
block: <<<256, 1, 1>>>
Launch Type: Regular
Static Shared Memory: 80 bytes
Dynamic Shared Memory: 0 bytes
Registers Per Thread: 208
Local Memory Per Thread: 0 bytes
Local Memory Total: 152,043,520 bytes
Shared Memory executed: 8,192 bytes
Shared Memory Bank Size: 4 B
Theoretical occupancy: **12.**5 %
Fast case:
Begins: 0.356016s
Ends: 0.358621s (+2.605 ms)
grid: <<<2400, 1, 1>>>
Registers Per Thread: 40
Local Memory Total: 94,371,840 bytes
Theoretical occupancy: 75 %
Hi tniemi and welcome,
This is an odd one in that nvc++ doesn’t do much here and simply uses the Thrust headers. Though you’re correct that the CUDA and Thrust version are the same between NVHPC 24.9 and 24.11, so something else changed.
The performance delta looks be coming from the reduce where the schedule changed, though I’ll need to ask engineering to look into why. I filed a problem report, TPR#37844, and have asked them to take a look.
-Mat
Thanks for looking into this.
Yes, registers are probably the issue here, or at least they hint what is the problem. Somehow the older compilers are able to produce optimized code, while newer ones fail. What is surprising is that in our actual code, the kernels can contain several tens of operations, including nasty branching max/mins, and it still works nicely with older compilers. With the new compilers, just a couple of plus ops is enough to crash the performance. Also, the issue is not related to specific algorithm, such as reduce, but even a simple call such as copy is enough to show the issue. In fact, eg.
thrust::copy(t3, t3 + N, vec_a.begin())
shows even worse performance of 80 ms vs 4 ms.
Although just using thrust headers, the compiler does have quite a job when it evaluates the final iterator. It can be a long sequence of function calls, which it should replace with the underlying primitive math ops and then optimize the whole thing. So it is quite an impressive feat when it works.
Hi tniemi,
Engineering let me know that TPR #37844 was fixed in our 25.11 release. I tested it on my system and see slightly better performance than 24.9 so there there may even be an improvement for you as well.
-Mat
Very good, thanks! I’ll run some tests with our codes and report back how it works.
Hi, based on my initial tests the issue seems to be resolved in 25.11 and indeed the performance with difficult kernels appear to be at least as good as in 24.9. It’ll take a while to gather more experience with 25.11, but so far everything looks good! Thank you!
