$ sudo /bin/bash /etc/systemd/scripts/nv_aurix_check_fw.sh
starting Aurix FW checking...
Checking arguments...
Rootfs FW version is 4.02.04.0
No_Response_From_Aurix
Ping to 10.42.0.146
Try with virtual ethernet iface
!!! IMPORTANT INFORMATION BELOW REGARDING Aurix FW (PLEASE READ) !!!
Aurix is booted with old FW which doesn't support Aurix OTA
Please Flash new FW from Windows based Flasher as provided by PDK
THIS MESSAGE WILL CONTINUE TO BE SHOWN UNTIL ACTION MENTIONED IS TAKEN
With action taken, this script will be muted and not shown again
Restore_default_network
and I tried camera type ar0231-rccb-bae-sf3325 and ar0231-rccb-ae-sf3325, got the same error
nvidia@tegra-ubuntu:/usr/local/driveworks/bin$ sudo /usr/local/driveworks/bin/sample_sensors_info
[13-4-2020 5:21:52] Initialize DriveWorks SDK v1.2.400
[13-4-2020 5:21:52] Release build with GNU 4.9.4 from v1.2.0-rc11-0-ga7f5475 against Vibrante PDK v5.0.10.3
[13-4-2020 5:21:52] Platform: Detected Drive PX2 - Tegra A
[13-4-2020 5:21:52] TimeSource: monotonic epoch time offset is 1586767287013397
[13-4-2020 5:21:52] TimeSource: PTP ioctl returned error. Synchronized time will not be available.
[13-4-2020 5:21:52] TimeSource: Could not detect valid PTP time source at ‘eth0’. Fallback to CLOCK_MONOTONIC.
[13-4-2020 5:21:52] Platform: number of GPU devices detected 2
[13-4-2020 5:21:52] Platform: currently selected GPU device discrete ID 0
[13-4-2020 5:21:52] SDK: Resources mounted from /usr/local/driveworks-1.2/data/resources
[13-4-2020 5:21:52] SDK: Create NvMediaDevice
[13-4-2020 5:21:52] SDK: Create NvMediaIPPManager
[13-4-2020 5:21:52] egl::Display: found 2 EGL devices
[13-4-2020 5:21:52] egl::Display: use drm device: drm-nvdc
Platform: OS_LINUX:
Sensor [0] : can.socket ? device=can0[,fifo-size=1024]
Sensor [1] : can.virtual ? file=/path/to/file.can[,create_seek,default_timeout_us,time-offset=0]
Sensor [2] : camera.virtual ? video/file=filepath.{h264,raw,lraw}[,timestamp=file.txt][,create_seek][,time-offset=0]
Sensor [3] : camera.nvidia-ip ? host=<ip_addr>, port=
Sensor [4] : camera.usb ? device=0
Sensor [5] : camera.pointgrey ? device=0[,fps=30]
Sensor [6] : gps.uart ? device=/dev/ttyXXX[,baud={1200,2400,4800,9600,19200,38400,57600,115200}[,format=nmea0183][,fifo-size=1024]]
Sensor [7] : gps.virtual ? file=filepath.bin[,create_seek,default_timeout_us,time-smoothing=true,time-offset=0]
Sensor [8] : gps.xsens ? device=0[,frequency=100,time-smoothing=true,fifo-size=1024,baudrate=115200,stop-bits=2]
Sensor [9] : gps.novatel ? [fifo-size=1024]
Sensor [10] : gps.dataspeed ? can-proto=can.socket,can-params=device=canX[,fifo-size=1024]
Sensor [11] : imu.uart ? device=/dev/ttyXXX[,baud={1200,2400,4800,9600,19200,38400,57600,115200}[,format=xsens_nmea][,fifo-size=1024]]
Sensor [12] : imu.xsens ? device=0[,frequency=100,time-smoothing=true,fifo-size=1024,baudrate=115200,stop-bits=2]
Sensor [13] : imu.virtual ? file=filepath.bin[,create_seek,default_timeout_us,time-smoothing=true][,fifo-size=1024][,time-offset=0]
Sensor [14] : imu.novatel ? [fifo-size=1024]
Sensor [15] : imu.dataspeed ? can-proto=can.socket,can-params=device=canX[,fifo-size=1024]
Sensor [16] : lidar.virtual ? file=filepath.bin[,create_seek,default_timeout_us,decoder=filepath.so,time-smoothing=false,decoding=true,time-offset=0]
Sensor [17] : lidar.socket ? ip=X.X.X.X,port=XXXX,device={QUAN_M81A, IBEO_LUX, VELO_VLP16, VELO_VLP16HR, VELO_HDL32E, VELO_VLP32C, VELO_HDL64E, CUSTOM},scan-frequency=XX.X[,protocol=xxx,multicast-ip=X.X.X.X,decoder=filepath.so,time-smoothing=false]
Sensor [18] : radar.virtual ? file=filepath.bin,time-smoothing=true[,decoder=filepath.so,create_seek,default_timeout_us,decoding=true,time-offset=0]
Sensor [19] : radar.socket ? ip=X.X.X.X,port=XXXX,device={DELPHI_ESR2_5, CONTINENTAL_ARS430, CUSTOM},multicast-ip=X.X.X.X],time-smoothing=true,isInverted=false,slave=false[,decoder=filepath.so,protocol=xxx]
Sensor [20] : radar.can ? can-driver=can.xxx,can-bus=xxx,can-base-id=0x460,device={CONTINENTAL_ARS430_CAN}[,aurix-can-ip=X.X.X.X.X],[aurix-can-aport=XXXX][,aurix-can-bport=XXXX][,virtual-file=filepath.bin][,time-smoothing=false]
Platform: OS_DRIVE_V5L - CURRENT:
Sensor [1] : can.aurix ? ip=10.0.0.1,bus={a,b,c,d}[,aport=50000,bport=60395][,fifo-size=1024]
Sensor [2] : can.virtual ? file=/path/to/file.can[,create_seek,default_timeout_us,time-offset=0]
Sensor [3] : camera.gmsl ? csi-port={a,c,e,g},camera-count={1,2,3,4},(Parker) camera-type={ov10635, ov10640-bggr-ae-svc210, ov10640-bggr-ae-svc212, ar0231-grbg-ae-sd3321, ar0231-rccb-ae-ss3322,ar0231-rccb-bae-ss3322, ar0231-rccb-ae-ss3323, ar0231-rccb-bae-ss3323, ar0231-rccb-ae-sf3324,ar0231-rccb-bae-sf3324, ar0231-rccb-ae-sf3325, ar0231-rccb-bae-sf3325},(Xavier) camera-type={ar0231-rccb-bae-sf3324, ar0231-rccb-bae-sf3325, ar0144-cccc-none-gazet1},output-format={yuv+raw+data}[,slave={0,1}][,fifo-size={3…20}][,custom-board=0][,camera-mask={0001|0010|0011|…|1111}][,warn-per-frame={0,1}]
Sensor [4] : camera.virtual ? video/file=filepath.{h264,raw,lraw}[,timestamp=file.txt][,create_seek][,time-offset=0]
Sensor [5] : camera.usb ? device=0
Sensor [6] : camera.pointgrey ? device=0[,fps=30]
Sensor [7] : camera.nvidia-ip ? host=[ip_addr], port=[TCP port number]
Sensor [8] : gps.uart ? device=/dev/ttyXXX[,baud={1200,2400,4800,9600,19200,38400,57600,115200}[,format=nmea0183]][,fifo-size=1024]
Sensor [9] : gps.virtual ? file=filepath.bin[,create_seek,default_timeout_us,time-smoothing=false,time-offset=0]
Sensor [10] : gps.xsens ? device=0[,frequency=100,time-smoothing=false,fifo-size=1024,baudrate=115200,stop-bits=2]
Sensor [11] : gps.novatel ? [fifo-size=1024]
Sensor [12] : gps.dataspeed ? can-proto=can.socket,can-params=device=canX[,fifo-size=1024]
Sensor [13] : imu.uart ? device=/dev/ttyXXX[,baud={1200,2400,4800,9600,19200,38400,57600,115200}[,format=xsens_nmea]][,fifo-size=1024]
Sensor [14] : imu.xsens ? device=0[,frequency=100,time-smoothing=false,fifo-size=1024,baudrate=115200,stop-bits=2]
Sensor [15] : imu.virtual ? file=filepath.bin[,create_seek,default_timeout_us,time-smoothing=false,time-offset=0]
Sensor [16] : imu.novatel ? [fifo-size=1024]
Sensor [17] : imu.dataspeed ? can-proto=can.socket,can-params=device=canX[,fifo-size=1024]
Sensor [18] : lidar.virtual ? file=filepath.bin[,create_seek,default_timeout_us,time-smoothing=false,decoding=true,time-offset=0]
Sensor [19] : lidar.socket ? ip=X.X.X.X,port=XXXX,device={QUAN_M81A, IBEO_LUX, VELO_VLP16, VELO_VLP16HR, VELO_HDL32E, VELO_VLP32C, VELO_HDL64E, CUSTOM},scan-frequency=XX.X[,protocol=xxx,multicast-ip=X.X.X.X,decoder=filepath.so,time-smoothing=false]
Sensor [20] : radar.virtual ? file=filepath.bin,time-smoothing=true[,decoder=filepath.so,create_seek,default_timeout_us,decoding=true,time-offset=0]
Sensor [21] : radar.socket ? ip=X.X.X.X,port=XXXX,device={DELPHI_ESR2_5, CONTINENTAL_ARS430, CUSTOM},multicast-ip=X.X.X.X,time-smoothing=true,isInverted=false,slave=false[,decoder=filepath.so,protocol=xxx]
Sensor [22] : radar.can ? can-driver=can.xxx,can-bus=xxx,can-base-id=0x460,device={CONTINENTAL_ARS430_CAN}[,aurix-can-ip=X.X.X.X.X],[aurix-can-aport=XXXX][,aurix-can-bport=XXXX][,virtual-file=filepath.bin]
Platform: OS_QNX:
Sensor [1] : can.virtual ? file=/path/to/file.can[,create_seek][,time-offset=0]
Sensor [2] : camera.gmsl ? csi-port={a,c,e,g},camera-count={1,2,3,4},camera-type={ar0231-rccb-bae-sf3324, ar0231-rccb-bae-sf3325},output-format={yuv+raw+data}[,slave={0,1}][,fifo-size={3..20}][,custom-board=0][,camera-mask={0001|0010|0011|..|1111}][,warn-per-frame={0,1}]
Sensor [3] : camera.virtual ? video/file=filepath.{h264,raw}[,timestamp=file.txt][,create_seek][,time-offset=0]
Sensor [4] : gps.uart ? device=/dev/ttyXXX[,baud={1200,2400,4800,9600,19200,38400,57600,115200}[,format=nmea0183]][,fifo-size=1024]
Sensor [5] : gps.virtual ? file=filepath.bin[,create_seek,default_timeout_us,time-smoothing=false,time-offset=0]
Sensor [6] : gps.xsens ? device=0[,frequency=100,time-smoothing=false,fifo-size=1024,baudrate=115200,stop-bits=2]
Sensor [7] : gps.dataspeed ? can-proto=can.socket/aurix,can-params=device=canX[,fifo-size=1024]
Sensor [8] : imu.uart ? device=/dev/ttyXXX[,baud={1200,2400,4800,9600,19200,38400,57600,115200}[,format=xsens_nmea]][,fifo-size=1024]
Sensor [9] : imu.virtual ? file=filepath.bin[,create_seek,default_timeout_us,time-smoothing=false,time-offset=0]
Sensor [10] : imu.xsens ? device=0[,frequency=100,time-smoothing=false,fifo-size=1024,baudrate=115200,stop-bits=2]
Sensor [11] : imu.dataspeed ? can-proto=can.socket/aurix,can-params=device=canX[,fifo-size=1024]
Sensor [12] : lidar.virtual ? file=filepath.bin[,create_seek,default_timeout_us,time-smoothing=false,time-offset=0]
Sensor [13] : lidar.socket ? ip=X.X.X.X,port=XXXX,device={QUAN_M81A, IBEO_LUX, VELO_VLP16, VELO_VLP16HR, VELO_HDL32E, VELO_VLP32C, VELO_HDL64E, CUSTOM},scan-frequency=XX.X[,protocol=xxx,multicast-ip=X.X.X.X,decoder=filepath.so,time-smoothing=false]
Sensor [14] : radar.virtual ? file=filepath.bin,time-smoothing=true[,decoder=filepath.so,create_seek,default_timeout_us,decoding=false,time-offset=0]
Sensor [15] : radar.socket ? ip=X.X.X.X,port=XXXX,device={DELPHI_ESR2_5, CONTINENTAL_ARS430, CUSTOM},multicast-ip=X.X.X.X],time-smoothing=true,isInverted=false[,decoder=filepath.so,protocol=xxx]
Sensor [16] : radar.can ? can-driver=can.xxx,can-bus=xxx,can-base-id=0x460,device={CONTINENTAL_ARS430_CAN}[,aurix-can-ip=X.X.X.X.X],[aurix-can-aport=XXXX][,aurix-can-bport=XXXX][,virtual-file=filepath.bin]
[13-4-2020 5:21:53] SDK: Release NvMediaDevice
[13-4-2020 5:21:53] Driveworks SDK released
[13-4-2020 5:21:53] SDK: Release NvMedia2D
The note indicates that the aurix version matters.
