SGIE_config.txt if i modified batch_size >1,there is error . and i got only one class in classifier engine
Are you using our demo or your own? Maybe your model only supports batch-size=1.
how about that i got only one class in classifier engine in two pictures. one should be wearing vest, another should be unwearing vest.
Could you describe your problem in detail?
is any problem on my SGIE_config.txt and this coding?
As I attached before, this is a problem with your model. You can check that from your log.
Backend has maxBatchSize 1 whreas 2 has been requested.
