Shadow Performance
Thanks for sharing Falcor.
There are plenty game engines out there, but very few render engines.
This could fill a void.
I managed to build Falcor on Ubuntu 16.04.4.
(Took manual build from source for ffmpeg and libglfw3, as those are too old on Ubuntu LTS.)
When I run the Shadow Sample, it struggles to even reach 14 FPS on my GTX 750 Ti.
What could be the reason for the poor performance?
I understand that it is an older GPU, yet Shadow mapping should not be that much of a challenge, surely?
Note that SimpleDeferred renders at 620fps, although that demo opens a smaller window.
NormalMap renders at 234fps for me at start up, but slows down to a trickle if I zoom in on the face.
It reports 40fps at that case, but is running much slower than reported.
I made some optimizations to the CSM class in the dev-3.0 branch.
One of the optimizations was to have a proper async SDSM buffer readback. I didn’t check performance on Linux yet - we were focusing on Windows and will spend the first week of April to make sure Linux works correctly. I also check the perf then.
Thanks for reporting all the issues!
