Share your latest Ascent GX10 idle power
Hi guys, still deciding between genuine Spark and Asus Ascent. I did research on idle power and it appears that after ConnectX power fix Nvidia can achieve 22W for single headless node, while Asus hovers around 30W. 8W would be considerable difference long term. Though there aren’t really that many reports anyway and almost no reports post May power delivery updates. So I was hoping, whoever cares, could you share your idle power consumption and confirm you’re on latest firmware, please? Thank you so much! 🙏
Lates firmware:
DGX OS - 25W with usb SSD attached
Ubuntu 26 - 26W usb SSD attached (OS on this SSD)
On my GX10 with 26.04 average is 25.5W. GPU is in D0 mode, couldn’t get it to D3Cold even without gdm running, probably not supported. Can you show your “cat /sys/class/drm/card*/device/power_state” output when only 22W?
With vllm running q35ba3b, 38C @ 10w while at idle. Literally perfect for winter this year, as it’ll have a latent heat pipe running underneath some indoor-planted veg.
