__shared__ command - 1 D stencil algorithm
I am new in CUDA and I am figuring out how to solve a simple problem.
I built a kernel, that computes a 1d stencil. It works
like this:
  • input vector:
in=(0,1,2,3,4,5,6,7,8,9);
  • As output I would have (for the stencil algorithm with radius=2):
out=(0,0,10,15,20,25,30,35,0,0)
My code works fine for small size vectors!
The code for my kernel:
__global__ void stencil(float *in, float *out) {
    __shared__ float temp[N];
    int i=threadIdx.x;
    temp[i+r]=in[i+r];
    if (i<r){
        temp[N-1-i]=in[N-1-i];
        temp[i]=in[i];}
    __syncthreads();
    float sum=0.0;
    for (int k=-r;k<=r;k++){
        sum+=temp[i+r+k];
    // --- Store the result
    out[i+r] = sum;
To call this I am using 1 Block and a number of threads
equal to each computed output value, that is N-2*r. In my main code
I call the kernel as:
stencil<<<1, N-2*r>>>(d_in, d_out);
My problem: how can I implement a similar code for N=1000000?
In a standard CUDA program I would increase the number of blocks. But unfortunately
in this case, I can’t do it because my algorithm is sharing memory between threads inside a block.
Thank you!
