i created solution with 2 projects
- myApp creates myApp.apk and myApp.so shared library
- myLib creates shared library myLib.so
in java app code
System.loadLibrary("myApp"); // works ok load lib
System.loadLibrary("myLib"); // hangs debugger
in my app i have 4 shared libs i would like to build them separately
than hopefully they would be installed and loaded.
i use nexus 7 which is not rooted as testing device
in standard eclipse projects shared libs are all located under jni folder
in nvidia visual studio addin only myApp.so lib is created under jni application folder
other shared libraries projects are created in project specific folders
something goes wrong when trying to load
sample which shows how to setup project with 2 shared libs with
lib2 depending on lib1 and both being
loaded by app using System.loadLibrary() would be helpful
