I just received a T10P board in the mail today, and was playing with the native double support in one of our kernels. While looking at profiler output, I noticed that the shared memory broadcast mechanism only works for 32-bit types. When I flipped one of our shared arrays from float to double, suddenly the warp_serialized counter was non-zero.
(Reading through the programming guide section on shared memory, it clearly states that broadcast applies to 32-bit words. So, this is documented behavior even though it surprised me.)
Is broadcasting a double to an entire half-warp equivalent to a 16-way bank conflict?
Shared memory does technically only support 32-bit words, but broadcasting a double to an entire half-warp should be the same as broadcasting two floats. So there should be no bank conflicts.
Are you sure the warp-serialize is not occuring when you write the doubles into shared memory? If threads write sequential doubles to shared memory, you will incur 2-way bank conflicts.
You could avoid this by splitting the high and low words of the doubles into separate arrays (much as you would with a struct with two floats, such as a complex type). However, this extra work may be more trouble than it is worth, since 2-way bank conflicts are only 2x slower than no conflicts…
This is a good point about the writing… And yes, bank conflicts are certainly not anywhere close to the performance bottleneck in this kernel, but I was curious about the change.
Regarding splitting a double into two 32-bit words and rejoining them, does this require using the __double2hiint()/__double2loinit() and __hiloint2double() functions? No discussion of these functions is given in B.2.2 in the Guide.
First, let me say this: I highly recommend you don’t split the doubles in software that you expect to be around for hardware, say, 12 to 24 months from now, because hardware in that timeframe may/should make it unnecessary, in which case splitting would perform worse than not splitting.
That said, here’s a relevant snippet from our current DGEMM code that does something similar.
__shared__ int AA_lo[(TILE_DIM+1)*TILE_DIM];
__shared__ int BB_lo[(TILE_DIM+1)*TILE_DIM];
__shared__ int AA_hi[(TILE_DIM+1)*TILE_DIM];
__shared__ int BB_hi[(TILE_DIM+1)*TILE_DIM];
AA_lo[idxAA] = __double2loint (parms.A[addrA]);
AA_hi[idxAA] = __double2hiint (parms.A[addrA]);
do {
dp = fma(__hiloint2double(AA_hi[li],AA_lo[li]),__hiloint2double(BB_hi[lj],BB_lo[lj]),dp);
li++;
lj++;
ll--;
} while (ll);
