I’m trying to create a shared version of “incrementarray.cu” at this address : http://www.ddj.com/cpp/207402986
Here’s my code :
[b]// incrementArray.cu
#include <stdio.h>
#include <cuda.h>
void incrementArrayOnHost(int *a, int N)
int i;
for (i=0; i < N; i++) a[i] = a[i]+1;
global void incrementArrayOnDevice(int a)
extern shared int s_data[];
int idx = blockIdx.xblockDim.x + threadIdx.x;
s_data[idx]=a[idx]+1;
__syncthreads();
int out = blockIdx.x*blockDim.x + threadIdx.x;
a[out]=s_data[out];
int main(void)
int *a_h, *b_h; // pointers to host memory
int a_d; // pointer to device memory
int i;
int N = 5124096;
printf("%d\n",N);
int numThreadsPerBlock = 512;
int numBlocks = N/ numThreadsPerBlock;
size_t size = N * sizeof(int);
// allocate arrays on host
a_h = (int *)malloc(size);
b_h = (int *)malloc(size);
// allocate array on device
cudaMalloc((void **) &a_d, size);
// initialization of host data
for (i=0; i<N; i++) a_h[i] = i;
// copy data from host to device
cudaMemcpy(a_d, a_h, size, cudaMemcpyHostToDevice);
// do calculation on host
incrementArrayOnHost(a_h,N);
// do calculation on device:
// Part 1 of 2. Compute execution configuration
//size_t memSize = numBlocks * numThreadsPerBlock * sizeof(int);
dim3 dimGrid(numBlocks);
dim3 dimBlock(numThreadsPerBlock);
//int blockSize = 4;
int sharedMemSize = numThreadsPerBlock * sizeof(int);
//int nBlocks = N/numThreadsPerBlock + (N%numThreadsPerBlock == 0?0:1);
// Part 2 of 2. Call incrementArrayOnDevice kernel
incrementArrayOnDevice <<< dimGrid,dimBlock, sharedMemSize >>> (a_d);
// Retrieve result from device and store in b_h
cudaMemcpy(b_h, a_d,size, cudaMemcpyDeviceToHost);
// check results
//int toto;
/* for (i=0; i<N; i++)
if(a_h[i]!=b_h[i])
toto=i;
i=2N;
printf("%d\n%d\n\n",a_h[514], b_h[514]);
// cleanup
int tr;
scanf("%d",&tr);
free(a_h); free(b_h); cudaFree(a_d);
}[/b]
Do i use shared memory properly ?The profiler find the same times for global version and shared version…
