Sharing Texture by Direct3D9 and register using Cuda
Iam trying to share texture using Direct3D9 and register it using cuD3D9RegisterResource(…).
So i should pass the sharedhandle parameter through Direct3D9- Createtexrure(…).
When i try to pass this parameter as “NULL” it works fine.
But I have to share the texture with multiple device and for this I have to pass the sharedhandle parameter.
But what happening here is :- if this parameter is passing as sharedhandle thus causes an error “CUDA_ERROR_INVALID_HANDLE”
Iam attaching a portion of my code here.
HANDLE sharedTextureHandle = NULL;
HRESULT hResult = pChInfo>pD3D9Device>CreateTexture(tVideoFormat.coded_width,tVideoFormat.coded_height, 1,
D3DUSAGE_RENDERTARGET /* | D3DUSAGE_NONSECURE*/,D3DFORMAT::D3DFMT_A8R8G8B8,
D3DPOOL::D3DPOOL_DEFAULT, &pChInfo->sharedD3DTexture, &sharedTextureHandle);
assert(S_OK == hResult);
/* get the surface level */
hResult = pChInfo->sharedD3DTexture->GetSurfaceLevel(0, &pChInfo->sharedD3DSurface);
checkCudaErrors(cuD3D9RegisterResource(&pChInfo->sharedD3DTexture, 0));//error “CUDA_ERROR_INVALID_HANDLE”
Is there any way to share the texture with multiple device using Direct3D9 and cuda interoperability.
