Shell has not been properly configured to use 'conda activate'
I am installing Tarantella following the instructions. After running the command
conda create -n tarantella
I have the following output:
Collecting package metadata (current_repodata.json): done
Solving environment: done
==> WARNING: A newer version of conda exists. <==
  current version: 22.9.0
  latest version: 23.3.1
Please update conda by running
    $ conda update -n base -c conda-forge conda
## Package Plan ##
  environment location: /opt/conda/envs/tarantella
Preparing transaction: done
Verifying transaction: done
Executing transaction: done
# To activate this environment, use
#     $ conda activate tarantella
# To deactivate an active environment, use
#     $ conda deactivate
Retrieving notices: ...working... done
Then I run the command
then get the output:
CommandNotFoundError: Your shell has not been properly configured to use 'conda activate'.
To initialize your shell, run
    $ conda init <SHELL_NAME>
Currently supported shells are:
  - bash
  - fish
  - tcsh
  - xonsh
  - zsh
  - powershell
See 'conda init --help' for more information and options.
IMPORTANT: You may need to close and restart your shell after running 'conda init'.
What do I need to do to be able to use conda active?
