as I think
(short)1 + (int)1
should be converted to (int)2 ?
again to the “call to ‘max’ is ambiguous” questions. In the script
[html]
short c = 1;
m = max( 0, 512 - abs(c - 512));
[/html]
both arguments should have (int) type?
as I think
(short)1 + (int)1
[html]
short c = 1;
[/html]
Unfortunately, they haven’t. OpenCL (1.0, page 177) specifies the abs function as:
The conversions take place in the following way
(step 1) max( <int> , <int> - abs( <short> - <int> )
(step 2) max( <int> , <int> - abs( <int> )
(step 3) max( <int> , <int> - <uint> )
(step 4) max( <int> , <uint> )
I’m programming C++ more often than C(99), but I am confident that the conversion rules are the same:
If an expression (here -) involves a signed and an unsigned integral, the type of the expression depends on the range of the types.
If the whole range of the unsigned type can be represented by the signed type (like in with 8 bit char), the expression yields the signed type.
If this is not the case ( has values that cannot be represented by ), the expression yields the unsigned type.
That conversion is neither intuitive, not portable, but it’s the C way (e.g. - is typically on 64 bit and on 32 bit machines).
thank you.
I can just remember, not understand the rule because (int) also has (negative) values that cannot be represented by (uint).
