Should i change the version of nsys
when i use the cuda,the driver version is here
the nsys verison is here
and when i use the nsight,it can’t be use
stay here for a long time ,should i change the nsys version?
Moved to the Nsight Systems category.
hello,what should i do in this category
Okay, you are using a pretty old version of Nsys,so I would be tempted to start by updating that from developer.nvidia.com/nsight-systems
The error message that you are seeing about the thread number and the hardware availability is not coming from Nsight Systems. Does this program run without the profiler?
One more possibility, when you are running the application, are you running it as a user who has the permission to write output files in that location?
You might need to redirect output, change directory permissions, or run as root.
