running Jetracer code and show error message as below, please kindly help
Hi goodeyedeer,
Thanks for reaching out!
This issue is caused by an operation that is not available in PyTorch 1.1. Could you try upgrading to PyTorch 1.2? You can find the installation instructions here
Alternatively, If you install torch2trt from master, it should also resolve this issue (non-existent PyTorch operations no longer cause hard failures). You can find it here
Please let me know if you have any questions.
Best,
John
