Show/Hide, SHow by Type, Physics, Collider, (None, Selected, All ) doesn’t perform as expected. The none button doesn’t deactivate the indicated. you first have to choose selected and then None to get the result you expect.
I also just noticed that this has an impact on the result you get from the Play (Space Button)
When Show/hide is set to none the physics animation won’t play.
