I have a linear float array, which contains vector values.
Something like this:
1 1 1 2 2 2 3 3 3
And I use it as 3 vectors with coordinates
x y z
1 1 1
2 2 2
3 3 3
The array is located in global memory and I want to make the vectors visible through an opengl buffer.
Is it possible to declare the array as float4 and to access the values like in a linear array?
The programming guide describes functions like make_float4(…). Is there a way to avoid the use of this function? If not, what is the cost of using it?
Best regards
