Showing confidence in the bounding box details
• Hardware Platform (Jetson / GPU) Jetson Xavier AGX
• DeepStream Version 6.0.1
• JetPack Version (valid for Jetson only) 4.6
• TensorRT Version 8.2.1
I am trying to the object detection confidence to the bounding box detection from the tracking sample gpubootcamp/Introduction_to_Multi-DNN_pipeline.ipynb at a647a2c3fc75828cbbf1cbd5ab29f865c491a35c · openhackathons-org/gpubootcamp · GitHub . The labels show the object class and the tracking ID, but I don’t understand how this information gets there. See image bellow:
I see that osd_sink_pad_buffer_probe(pad,info,u_data) displays the information on the image frame, but I can’t see where it states that class and tracker id must be placed at the top of the bounding box. And I want to include the object confidence.
I know I can get the confidence from object in this loop, by accessing obj_meta.confidence
while l_obj is not None:
    try:
        # Casting l_obj.data to pyds.NvDsObjectMeta
        obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
    except StopIteration:
        break
    obj_counter[obj_meta.class_id] += 1
    obj_meta.rect_params.border_color.set(0.0, 0.0, 1.0, 1.0)
    obj_meta.text_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
    obj_meta.text_params.text_bg_clr.set(0.0, 0.0, 1.0, 1.0)
    # Can get confidence by accessing obj_meta.confidence
    try:
        l_obj = l_obj.next
        break
Therefore, how I can define what is shown in the bounding box text?
Thanks in advance,
Flávio Mello
Hi @flavio.mello
Something like this should do the trick:
        batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(buf))
        frame_meta_list = batch_meta.frame_meta_list
        while frame_meta_list:
            frame_meta = pyds.NvDsFrameMeta.cast(frame_meta_list.data)
            obj_meta_list = frame_meta.obj_meta_list
            while obj_meta_list:
                object_meta = pyds.NvDsObjectMeta.cast(obj_meta_list.data)
                confidence = object_meta.confidence
                display_text = pyds.get_string(object_meta.text_params.display_text)
                object_meta.text_params.display_text = display_text + " " + str(confidence)
                obj_meta_list = obj_meta_list.next
            frame_meta_list = frame_meta_list.next
I’m not sure if the python version works, because I perform most of the meta manipulation on C.
The C++ tip helped a lot. This is the python code:
obj_display_text = pyds.get_string(obj_meta.text_params.display_text) + ' {:.2f}%'.format(obj_meta.confidence * 100)
obj_meta.text_params.display_text = obj_display_text
