I follow “Hello AI World (Inference Only)” instruction and built successfully. The board always shutdown after executing command.
I would like to know if anyone else is experiencing similar problems, and if anyone has a solution.
Hi David, it would appear that you are using the Micro-USB port for power - what amperage/current does your charger support? It would appear that the Nano is exceeding the power limitations of your USB charger or cable.
Two suggestions:
