We designed a carrier board,in ubantu22.04.5,when the module initiates a software system shutdown,the SHUTDOWN_REQ signal may probabilistically fail to be asserted and system hang;
module p/n:900-13767-0010-001
The issue you’re experiencing with the Jetson Orin NX module (PN 900-13767-0010-001) on your custom carrier board, where the SHUTDOWNREQ signal may probabilistically fail to be asserted and the system hangs during a software system shutdown, is likely related to the specific configuration and design of your carrier board.
To troubleshoot this issue, let’s consider the following:
Comparing this to the Jetson AGX Orin Developer Kit (P3730-0000), which consists of a P3701 System on Module (SOM) connected to a P3737 carrier board, we can see that the Developer Kit has a specific thermal solution designed for the kit, and the SOM can be used without any software configuration modifications.
In contrast, your custom carrier board design may require specific configuration and design considerations to ensure proper functionality, including the shutdown process.
To resolve the issue, you may need to:
If the issue persists, it may be helpful to consult the Jetson Orin NX module datasheet and the NVIDIA Jetson Linux Developer Guide for further guidance on designing and configuring a custom carrier board.
Can you please provide scope captures of the behavior of the SHUTDOWN_REQ and your carrier board’s power down sequence, including the POWER_EN and SYS_RESET signals, when this happens?
When system hangs,SHUTDOWN_REQ is always high,so POWER_EN and SYS_RESET held high level,system would not shutdown
Thanks ~0708
Hi jason.chen,
How did you trigger the software shutdown?
Could you share the full serial console log for further check?
