SI test on usb and pcie
out schematic, please FYI
Did you do step 1 and 2 to plug in a usb device and disable auto-suspend?
Yes, we plug a usb disk into the socket and disable auto-suspend.
Is it a type-C connector? There is no recommended type-C design for nano.
Can you test USB0 port following the guide? If that works on USB0, it should work on USB1 if follow the design guide.
We use the type-C conntector, because it is combin with USB3.0 interface, In addition, we haven’t tested the usb0 (OTG) port. Next, we try to test the usb0 port
Test usb0 log:
cat state USB=0
USB_HOST=1
root@localhost:/sys/devices/extcon/extcon:extcon@1/extcon/extcon0# cd
root@localhost:~# echo on > /sys/bus/usb/devices/usb1/power/control
root@localhost:~# echo on > /sys/bus/usb/devices/usb2/power/control
root@localhost:~# busybox devmem 0x70090460
0x000002A0
root@localhost:~# busybox devmem 0x70090460 16 0xa0
0x00000080
root@localhost:~# busybox devmem 0x70090020
0x00000805
root@localhost:~# busybox devmem 0x70090020 16 0x804
0x00000804
root@localhost:~# busybox devmem 0x70090024
0x00000001
root@localhost:~# busybox devmem 0x70090464
0x00000000
root@localhost:~# busybox devmem 0x70090464 32 0x10000000
0x10000000
root@localhost:~# busybox devmem 0x7009F088
0x04CD1011
root@localhost:~# busybox devmem 0x7009F088 32 0x00cd1011
0x00CD1011
