I am unable to update the driver to 390.42 as the installer fails hard on SIGBUS error. the fail occurs when the existing driver is being uninstalled.
on: linux-4.4.114-42-default
# lspci for VGA
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation Device [10de:1c02] (rev a1) (prog-if 00 [VGA controller])
Subsystem: NVIDIA Corporation Device [10de:11c2]
Flags: fast devsel, IRQ 16
Memory at f6000000 (32-bit, non-prefetchable)
Memory at e0000000 (64-bit, prefetchable)
Memory at f0000000 (64-bit, prefetchable)
I/O ports at e000
Expansion ROM at f7000000 [disabled]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Legacy Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [250] Latency Tolerance Reporting
Capabilities: [128] Power Budgeting <?>
Capabilities: [420] Advanced Error Reporting
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] #19
Kernel modules: nouveau, nvidia_drm, nvidia
installer log file here: Hastebin: Send and Save Text or Code Snippets for Free | Toptal®
nvidia-bug-report.log.gz (106 KB)
