Hi, I start working on some version of FFT. My last code of radix-4 get diferent result on NVidia and Ati cards.
Problem is on my Nvidia card 460 GT. I tried this on Ati radeon HD 5450 and the result is ok.
__kernel void fft_radix4(__global const float2 * x,__global float2 * y,int p)
int t = get_global_size(0); // number of threads
int i = get_global_id(0); // current thread
int k = i & (p-1); // index in input sequence, in 0..P-1
// Inputs indices are I+{0,1,2,3}*T
x += i;
// Output indices are J+{0,1,2,3}*P, where
// J is I with two 0 bits inserted at bit log2(P)
y += ((i-k)<<2) + k;
// Load and twiddle inputs
// Twiddling factors are exp(_I*PI*{0,1,2,3}*K/2P)
float alpha = -FFT_PI*(float)k/(float)(2*p);
// Load and twiddle, one exp_alpha computed instead of 3
float2 twiddle = exp_alpha_1(alpha);
float2 u0 = x[0];
float2 u1 = mul_1(twiddle,x[t]);
float2 u2 = x[2*t];
float2 u3 = mul_1(twiddle,x[3*t]);
twiddle = sqr_1(twiddle);
u2 = mul_1(twiddle,u2);
u3 = mul_1(twiddle,u3);
// 2x DFT2 and twiddle
float2 v0 = u0 + u2;
float2 v1 = u0 - u2;
float2 v2 = u1 + u3;
float2 v3 = mul_p1q2(u1 - u3); // twiddle
// 2x DFT2 and store
y[0] = v0 + v2;
y[p] = v1 + v3;
y[2*p] = v0 - v2;
//v3.y = -v3.y; <-- doesn't change
y[3*p] = v1 - v3; <-- error in sign
I have a sequence of 8 numbers: 0, 1, 2, 3, 4, 5, 6, 7
Result after kernel executions is:
0 +12.000000 +0.000000
1 -4.000000 +4.000000
2 -4.000000 +0.000000
3 -4.000000 +4.000000 << should be -4.000000 -4.000000 (Ati cards are ok, nvidia no)
4 +16.000000 +0.000000
5 -4.000000 +4.000000
6 -4.000000 +0.000000
7 -4.000000 +4.000000 << should be -4.000000 -4.000000 (Ati cards are ok, nvidia no)
v1 = -4 and v3 = +4i in both threads
Why v1 - v3 = -4 + 4i. It should equal -4 - 4i.
Someone tell me what’s wrong?
