I get a strange access violation error.
Please refer to code sections below.
- Calling part
SUBROUTINE InitMPIAxNSolver(Core, GroupInfo, ng0, AxSolver, PE)
USE PARAM
USE Typedef, ONLY : PE_TYPE, CoreInfo_Type, AxFlx_Type, GroupInfo_Type, PE_TYPE
USE P1SENM_MOD, ONLY : AllocP1AxFlxType
USE SP3SENM_MOD, ONLY : AllocSP3AxFlxType
IMPLICIT NONE
TYPE(CoreInfo_Type) :: Core
TYPE(GroupInfo_Type) :: GroupInfo
TYPE(PE_TYPE) :: PE
INTEGER :: ng0, AxSolver
INTEGER :: iz, itid
!LOGICAL :: lfirst
!DATA lfirst / TRUE /
!IF(.NOT. lfirst) THEN
! DEALLOCATE(XS)
!ENDIF
!DATA lfirst /.false./
ng = ng0; nxy = Core%nxy
nz = PE%nz; nzfm = PE%nzfm
myzb = PE%myzb; myze = PE%myze
myzbf = PE%myzbf; myzef = PE%myzef
SubPlaneMap => Core%SubPlaneMap
AxGeom%ng = ng0
AxGeom%ncomp = nzfm; AxGeom%nMesh =nzfm
AxGeom%myzb = 1; AxGeom%myze = nz
AxGeom%myzbf = 1; AxGeom%myzef = nzfm
AxGeom%BC = Core%AxBC
AxGeom%H => Core%Hzfm; AxGeom%HInv => Core%HzfmInv
AxGeom%Comp => Core%SubPlaneMap
CALL AllocMpiAxSol(AxSolver, GroupInfo, ng0, PE)
ALLOCATE(XS(Core%nzfm, PE%nAxThread))
ALLOCATE(FLXOMP(Core%nzfm, PE%nAxThread))
DO itid = 1, PE%nAxThread
DO iz = 1, Core%nzfm
IF(AxSolver .EQ. lP1SENM) THEN
CALL AllocP1AxFlxType(FLXOMP(iz, itid), ng0, .TRUE.)
ELSEIF(AxSolver .EQ. lP3SENM) THEN
CALL AllocSp3AxFlxType(FLXOMP(iz, itid), ng0, .TRUE.)
ENDIF
CALL AllocPinXS(XS(iz, itid), ng0, 4, GroupInfo%InScatRange)
ENDDO
ENDDO
!IF(PE%nCmfdProc .EQ. 1) MpiLkg => Lkg
END SUBROUTINE
- Called part
SUBROUTINE AllocPinXS(PinXS, ng, nbd, InScatRange)
USE PARAM
USE TYPEDEF, ONLY : PinXs_Type
USE ALLOCS
IMPLICIT NONE
TYPE(PinXs_Type) :: PinXs
INTEGER :: ng, nbd !Number of Groups and Number of Boundaries
INTEGER, POINTER :: InScatRange(:, :)
INTEGER :: ig, igb, ige
CALL Dmalloc(PinXS%Dtil, nbd, ng); CALL Dmalloc(PinXs%Dhat, nbd, ng)
CALL Dmalloc(PinXS%atil, nbd, ng); CALL Dmalloc(PinXS%ahat, nbd, ng) !--- CNJ Edit : Domain Decomposition
CALL Dmalloc(PinXs%PDhat, nbd, ng)
CALL Dmalloc(PinXS%AxDtil, 2, ng); CALL Dmalloc(PinXs%AxDhat, 2, ng)
CALL Dmalloc(PinXS%Dtil2, nbd, ng)
CALL Dmalloc(PinXs%XSD, ng); CALL Dmalloc(PinXs%XSD2, ng); CALL Dmalloc(PinXs%XSA, ng); !---BYS edit
CALL Dmalloc(PinXs%XST, ng); CALL Dmalloc(PinXs%XSTR, ng)
CALL Dmalloc(PinXs%XSR, ng); CALL Dmalloc(PinXs%XSNF, ng)
CALL Dmalloc(PinXs%XSKF, ng); CALL Dmalloc(PinXs%CHI, ng)
CALL Dmalloc(PInXs%phi, ng); CALL Dmalloc(PInXs%FAC, ng)
ALLOCATE(PinXS%XSS(ng))
PRINT *, UBOUND(InScatRange, DIM = 1), UBOUND(InScatRange, DIM = 2) !--- Signalled ACCESS_VIOLATION
DO ig = 1, ng
igb = InScatRange(1, ig); ige = InScatRange(2, ig)
CALL Dmalloc0(PinXs%Xss(ig)%From, igb, ige)
PinXs%Xss(ig)%ib = igb; PinXs%Xss(ig)%ie = ige
ENDDO
END SUBROUTINE
- Type definition
TYPE GroupInfo_Type
SEQUENCE
LOGICAL :: lUpScat, ldum
INTEGER :: ng, nofg, norg, nchi, ntiso
INTEGER :: nFxSub, nCatMg
INTEGER :: UpscatRange(2)
INTEGER, POINTER :: InScatRange(:, :), OutScatRange(:, :)
INTEGER :: nGC !Number of Condensed Group
INTEGER :: GCStruct(2,300) !Coarse Group => Fine Group
INTEGER :: InvGCStruct(300) !FineGroup => Coarse Group
INTEGER :: nprec = 6
END TYPE
- Interface
USE PARAM
IMPLICIT NONE
INTEGER :: ng, nbd
END SUBROUTINE
AllocPinXS is successfully called, and the print line correctly prints upper bounds of the array InScatRange.
But then the compiler returns access violation error at the print line.
What am I doing wrong?
If I use
INTEGER :: InScatRange(2, ng)
instead of
the code works fine. Isn’t it strange? I’m passing pointer.
