elhe
November 9, 2021, 3:30pm
#1
I always get the error message nvbuf_utils:
dmabuf_fd -1853180096 mapped entry NOT found
Caught SIGSEGV
When I try to free a std::vector<std::vector<NvBufSurface*>>
called buffer
in a loop over each element.
Something like this:
for(int i=0; i<x; i++){
for(int j=0; j<y; j++){
NvBufSurfaceDestroy(buffer.at(i).at(j))
x and y
are the same for the creation of the NvBufSurface
Any ideas on why this might be happening.
DaneLLL
November 10, 2021, 2:35am
#3
The dmabuf fd looks invalid. Do you call NvBufSurfaceCreate() to create the buffer? Or how the buffer is created?
elhe
November 10, 2021, 6:06am
#4
Hi @DaneLLL ,
Yes it is created using NvBufSurfaceCreate
followed by NvBufSurfaceMemSet
The NvBufSurfaceCreate
is called with the following parameter:
params.gpuId = DEFAULT_GPU_ID;
params.memType = NVBUF_MEM_SURFACE_ARRAY;
params.isContiguous = false;
params.width = width;
params.height = height;
params.size = 0;
params.layout = NVBUF_LAYOUT_PITCH;
params.colorFormat = NVBUF_COLOR_FORMAT_NV12;
Because I allocate upt to 100 NvBufSurfaces I checked my Ram, but this seems to be fine. Is there an artifical limit on how much NvBufSurfaces you can have?
DaneLLL
November 10, 2021, 6:52am
#5
If you can create the buffer successfully, should be able to destroy it. Could you print out buffer.at(i).at(j)
for a check? To make sure the fd is valid before calling NvBufSurfaceDestroy() .
elhe
November 10, 2021, 2:51pm
#6
Hi @DaneLLL
The output is:
Vector of vectors
ptr: 0
ptr: 5ec0bfa0
ptr: 0
ptr: 5ec0c180
ptr: 0
ptr: 5ec0c520
ptr: 0
ptr: 5ec0c1d0
ptr: 0
ptr: 5ec0c260
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
ptr: 0
ptr: 5ec0c2f0
But now I am wondering,
my function for allocating NvBufSurface is this:
void AllocateNvBufSurface(NvBufSurface **surface, int width, int height, NvBufSurfaceLayout layout) noexcept {
NvBufSurfaceCreateParams params;
if (*surface != nullptr) {
NvBufSurfaceDestroy(*surface);
*surface = nullptr;
params.size = 0;
params.layout = layout;
g_print("ptr: %x\n", *surface);
CHECK_NVBUFSURFACE_STATUS(NvBufSurfaceCreate(surface, 1, ¶ms), "Error: Could not allocate internal buffer for NvBufSurface at Startup");
CHECK_NVBUFSURFACE_STATUS(NvBufSurfaceMemSet(*surface, 0, 0, 0), "Error: Can't set all values of NvBufSurface at startup to 0");
And I get
ptr: 0
ptr: 5ebe0c40
ptr: 0
ptr: 5ec0acc0
ptr: 0
ptr: 5ec0b300
ptr: 0
ptr: 5ec0b940
Even for the surfaces I allocate separately and deallocate with NvBufSurfaceDestroy and that works without a problem.
DaneLLL
November 11, 2021, 3:16am
#7
Is it possible the vectors are corrupted? Not sure if it is an issue but 5ec0c2f0
is read out for multiple times.
elhe
November 11, 2021, 5:27am
#8
Hi @DaneLLL ,
I wouldn’t know how. So far I am only allocating and deallocating it and I don’t use it for anything yet.
elhe
November 11, 2021, 6:11am
#9
@DaneLLL ,
It seems that I found the error. Within the allocation loop I create a structure that contains the NvBufSurface and some other variables. I create this on stack and push it back to the vector. It seems I exceeded the stack size. I now remodeled it with the creation of these structures on the heap and it doesn’t fail anymore.
Thanks for helping again.
system
closed
December 1, 2021, 6:19am
#11
