I’m trying a simple gstreamer pipeline with my freshly trained yolov3 model but endup with a sigsegv when running the pipeline…
gst-launch-1.0 uridecodebin uri= file:///home/jetson/ml/data/videos/lovefish_terrasse_cam04_01.mp4 ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=720 ! nvinfer config-file-path=config_infer_primary_yoloV3.txt ! fakesink
Setting pipeline to PAUSED ...
Deserialize yoloLayerV3 plugin: yolo_83
Deserialize yoloLayerV3 plugin: yolo_95
Deserialize yoloLayerV3 plugin: yolo_107
Pipeline is PREROLLING ...
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
WARNING: Num classes mismatch. Configured:2, detected by network: 80
Caught SIGSEGV
#0 0x0000007fb465f048 in __GI___poll (fds=0x55c0ac7d90, nfds=548488528496, timeout=<optimized out>) at ../sysdeps/unix/sysv/linux/poll.c:41
#1 0x0000007fb476be40 in () at /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0
#2 0x00000055987483a0 in ()
Spinning. Please run 'gdb gst-launch-1.0 7360' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
Any idea to get more clue as of where this sigsegv happens ?
Cheers
