We have a use case where we want to pre-build model engines automatically, not when nvinfer is launched, and without parsing .txt files.
For that, we use nvdsinfer
source code, available at path: /opt/nvidia/deepstream/deepstream-5.0/source/libs/nvdsinfer
. This is a minimal, reproducible example of what we do:
main.cpp (4.7 KB)
In this code, we build a yolov3-tiny
model, and then a peoplenet
model.
The yolov3-tiny
one builds fine, but peoplenet
segfaults.
When only building peoplenet
, it works. When building peoplenet
and then yolov3-tiny
both work too.
So order has an influence.
Here is the gdb output:
(gdb) info threads
Id Target Id Frame
* 1 Thread 0x7fa0a83560 (LWP 29112) "test_main" 0x0000007faa7c0434 in ?? () from /usr/lib/aarch64-linux-gnu/libnvparsers.so.7
2 Thread 0x7f999ef9b0 (LWP 29332) "cuda-EvtHandlr" 0x0000007faa1f0048 in __GI___poll (fds=0x559d1ad590, nfds=4294967295, timeout=<optimized out>) at ../sysdeps/unix/sysv/linux/poll.c:41
3 Thread 0x7f927f59b0 (LWP 30824) "test_main" 0x0000007faa09a9c8 in futex_abstimed_wait_cancelable (private=0, abstime=0x0, expected=0, futex_word=0x55558f2460)
at ../sysdeps/unix/sysv/linux/futex-internal.h:205
(gdb) backtrace
#0 0x0000007faa7c0434 in ?? () from /usr/lib/aarch64-linux-gnu/libnvparsers.so.7
#1 0x0000007faa7c3918 in ?? () from /usr/lib/aarch64-linux-gnu/libnvparsers.so.7
#2 0x0000007fb7e620f8 in ?? () from /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_inferutils.so
#3 0x0000007fb7e62790 in NvDsInferCudaEngineGetFromTltModel () from /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_inferutils.so
#4 0x0000005555560768 in nvdsinfer::TrtModelBuilder::getCudaEngineFromCustomLib (this=0x559d1984b0, cudaEngineGetDeprecatedFcn=0x0,
cudaEngineGetFcn=0x7fb7e622d0 <NvDsInferCudaEngineGetFromTltModel>, initParams=..., networkMode=@0x7ffffe5900: NvDsInferNetworkMode_FP32)
at ../tegra_platform/nvds_model_builder/nvdsinfer_model_builder.cpp:791
#5 0x0000005555560b64 in nvdsinfer::TrtModelBuilder::buildModel (this=0x559d1984b0, initParams=..., suggestedPathName="") at ../tegra_platform/nvds_model_builder/nvdsinfer_model_builder.cpp:858
#6 0x000000555555a598 in buildModel (params=...) at ../tegra_platform/nvds_model_builder/main.cpp:109
#7 0x000000555555a7b8 in main () at ../tegra_platform/nvds_model_builder/main.cpp:126
(gdb) thread 2
[Switching to thread 2 (Thread 0x7f999ef9b0 (LWP 29332))]
#0 0x0000007faa1f0048 in __GI___poll (fds=0x559d1ad590, nfds=4294967295, timeout=<optimized out>) at ../sysdeps/unix/sysv/linux/poll.c:41
41 ../sysdeps/unix/sysv/linux/poll.c: No such file or directory.
(gdb) backtrace
#1 0x0000007f9fcd20a0 in ?? () from /usr/lib/aarch64-linux-gnu/libcuda.so
#2 0x0000007f9fd52b94 in ?? () from /usr/lib/aarch64-linux-gnu/libcuda.so
#3 0x0000007f9fcd44bc in ?? () from /usr/lib/aarch64-linux-gnu/libcuda.so
#4 0x0000007faa092088 in start_thread (arg=0x7ffffe508f) at pthread_create.c:463
#5 0x0000007faa1f94ec in thread_start () at ../sysdeps/unix/sysv/linux/aarch64/clone.S:78
(gdb) thread 3
[Switching to thread 3 (Thread 0x7f927f59b0 (LWP 30824))]
#0 0x0000007faa09a9c8 in futex_abstimed_wait_cancelable (private=0, abstime=0x0, expected=0, futex_word=0x55558f2460) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
205 ../sysdeps/unix/sysv/linux/futex-internal.h: No such file or directory.
(gdb) backtrace
#1 do_futex_wait (sem=sem@entry=0x55558f2460, abstime=0x0) at sem_waitcommon.c:111
#2 0x0000007faa09aae8 in __new_sem_wait_slow (sem=0x55558f2460, abstime=0x0) at sem_waitcommon.c:181
#3 0x0000007f9fcd26a0 in ?? () from /usr/lib/aarch64-linux-gnu/libcuda.so
#4 0x0000007f9fcbdfb4 in ?? () from /usr/lib/aarch64-linux-gnu/libcuda.so
#5 0x0000007f9fcd44bc in ?? () from /usr/lib/aarch64-linux-gnu/libcuda.so
#6 0x0000007faa092088 in start_thread (arg=0x7ffffe0f3f) at pthread_create.c:463
#7 0x0000007faa1f94ec in thread_start () at ../sysdeps/unix/sysv/linux/aarch64/clone.S:78
• Hardware Platform: Jetson AGX Xavier
• DeepStream Version: 5.0 GA
• JetPack Version: 4.4
• TensorRT Version: 7.1.3
