simple cdot implementation beginner question
__global__ void
testKernel( float* g_idata, float* g_odata,int block_size_x,
  	int block_size_y, int grid_size_x, int grid_size_y, const int N)
	int index = blockIdx.x * block_size_x + threadIdx.x;
 if (index < N ) {
   g_odata[0] += g_idata[index] * g_idata[index];
Why this is not working as expected ?
thx a lot
Because you have every single thread on the device trying to increment the same memory location simultaneously. Read-modify-write is not an atomic operation. See the scalarProd project in the SDK for a complete description of how to implement this operation. Or search the forums for the numerous other threads that discuss the read-modify-write issue in more detail.
Edit: Ack double post.
ahhh thanks a lot … i was wondering why it worked without the incementation.
i had the same problem some weeks ago, too. And for me this thread (especially the last answer) was very helpful.
http://forums.nvidia.com/index.php?showtopic=42642
