I’m having a brain fart and cannot remember how to do this.
I need to allocate memory in CUDA for a few integers and copy over some numbers over. What did write wrong?
[codebox]
unsigned int d_col;
cudaMalloc((void*) &d_col, sizeof(unsigned int));
cudaMemcpy(d_col, col, sizeof(unsigned int), cudaMemcpyHostToDevice);
[/codebox]
Did you forget some thing? ;)
unsigned int d_col = NULL;
I tried what you said and here are the errors that I received from the compiler
error: argument of type “unsigned int” is incompatible with parameter of type “const void *”
error: argument of type “unsigned int *” is incompatible with parameter of type “unsigned int”
What do you think?
I think you variable col in
isn’t a pointer, when it should be. I also think you need consult this (your have your own copy wherever the CUDA toolkit is installed) and maybe brush up on the C chops a little.
[quote name=‘avidday’ post=‘581174’ date=‘Aug 21 2009, 11:05 AM’]
[codebox]unsigned int *d_row=NULL;
cudaMalloc((void**) &d_row, sizeof(unsigned int));
cudaMemcpy(&d_row, &row, sizeof(unsigned int), cudaMemcpyHostToDevice);[/codebox]
and the error is now: argument of type “unsigned int **” is incompatible with parameter of type “unsigned int *”
Also if it helps in the kernel when I try to use row I receive this error: expression must have arithmetic or enum type
unsigned int row=(unsigned int)malloc(sizeof(unsigned int));
//initialize data for row variable and then, copy data from host to device memory
unsigned int d_row=NULL;
cudaMalloc((void*) &d_row, sizeof(unsigned int));
cudaMemcpy(d_row, row, sizeof(unsigned int), cudaMemcpyHostToDevice);
