hi all,
I got some problem about using cublas library. Now, I have two matrices to multiply, but result is error.
I can’t find out problem in my code. Any somebody can help me, please.
Matrix P is : (NxN)
[0] [I]
[0] [-J]
[J] [0]
[I] [0]
here [0] is zero matrix, [I] is identity,
[J] = 0 0 0 0 1
0 0 0 1 0
0 0 1 0 0
0 1 0 0 0
1 0 0 0 0
[0], [I] and [J] both is (N/4 x N/4) matrices.
here is my code
[codebox]
#include <math.h>
#include <cuda.h>
#include <cuda_runtime.h>
#include <cutil.h>
#include <cutil_inline.h>
#include “cublas.h”
using namespace std;
#define IDX2C(i,j,ld) (((j)*(ld))+(i))
/* Allocate host memory for the matrices */\
#define HOSTmalloc(H_ptr,N, id);{\
H_ptr = (float*)malloc(N * sizeof(H_ptr[0]));\
if (H_ptr == 0) {\
fprintf (stderr, "!!!! (%dth)host memory allocation error.\n", id);\
return EXIT_FAILURE;\
memset(H_ptr, 0, N * sizeof(H_ptr[0]));\
int first_algo1();
int LOG_N;
long N;
float* h_S;
float* h_P;
unsigned int n2;
unsigned int np;
int main(int argc, char* argv)
LOG_N = 6;
N = 1;
N = N << LOG_N;
/**************** start ************/
n2 = N/2 * N/2;
np = N * N/2;
HOSTmalloc(h_S, n2, 1);
HOSTmalloc(h_P, np, 2);
long n4 = N/2 * N/2;
float* I;
float* J;
HOSTmalloc(I, n4, 7);
HOSTmalloc(J, n4, 8);
/* Fill the matrices with test data */
/*!!!!!!! column major !!!!!!! */
for(long i=0; i < N/2; i++){
for(long j=0; j< N/2; j++){
long idx = IDX2C(i, j, N/2);
h_S[idx] = 1;
* | [0] [I] |
* P= | [0] [-J] |
* | [J] [0] |
* | [-I] [0] | N by N matrix
* I = | 1 0 0 |
* | 0 : 0 |
* | 0 0 1 |
* J = | 0 0 1 |
* | 0 : 0 |
* | 1 0 0 |
for(long i=0; i < N/4; i++){
for(long j=0; j< N/4; j++){
long idx =IDX2C(i, j, N/4);
I[idx] = 0.0f;
J[idx] = 0.0f;
if(i == j)
I[idx] = 1.0;
if((i+j) == N/4-1)
J[idx] = 1.0;
for(long i=0; i < N; i++){
long idx = IDX2C(i, j, N);
h_P[idx] = 0.0f;
if(j>= N/4){
if(i < N/4){
//h_P[idx] = I[i][j-N/4];
long Midx = IDX2C(i, j-N/4, N/4);
h_P[idx] = I[Midx];
}else if(i >= N/4 && i < N/2){
//h_P[idx] = -1*J[i-N/4][j-N/4];
long Midx = IDX2C(i-N/4, j-N/4, N/4);
if(J[Midx] != 0)
h_P[idx] = -1*J[Midx];
}else if(j < N/4){
if(i >= (N/2) && i < 3*N/4){
//h_P[idx] = J[i-N/2][j];
long Midx = IDX2C(i-N/2, j, N/4);
h_P[idx] = J[Midx];
}else if(i >= 3*N/4){
//h_P[idx] = I[i-3*N/4][j];
long Midx = IDX2C(i-3*N/4, j, N/4);
h_P[idx] = -I[Midx];
first_algo1();
free(h_S);
free(h_P);
return 0;
#define CUBLASmalloc(N, D_ptr, ID);{\
/* Allocate device memory for the matrices */\
status = cublasAlloc(N, sizeof(D_ptr[0]), (void**)&D_ptr);\
if (status != CUBLAS_STATUS_SUCCESS) {\
fprintf (stderr, "!!!! (%dth)device memory allocation error\n",ID);\
#define CUBLASset(N, H_ptr, D_ptr, ID);{\
/* Initialize the device matrices with the host matrices */\
status = cublasSetVector(N, sizeof(H_ptr[0]), H_ptr, 1, D_ptr, 1);\
fprintf (stderr, "!!!! device access error (write :%dth)\n", ID);\
#define CUBLASget(N, H_ptr, D_ptr);{\
/* Read the result back */\
status = cublasGetVector(N, sizeof(H_ptr[0]), D_ptr, 1, H_ptr, 1);\
fprintf (stderr, "!!!! device access error (read C)\n");\
#define CUBLASfree(D_ptr, id);{\
status = cublasFree(D_ptr);\
fprintf (stderr, "!!!! memory free error (%dth)\n", id);\
int first_algo1()
cublasStatus status;
float* d_S = 0;
float* d_P = 0;
float alpha = 1.0f;
float beta = 0.0f;
/* Initialize CUBLAS */
status = cublasInit();
fprintf (stderr, "!!!! CUBLAS initialization error\n");
status = cublasGetError();
fprintf (stderr, "!!!! kernel execution error.\n");
// x = P * S * L * DCT' * D * X
CUBLASmalloc(np, d_P, 5);
CUBLASset(np, h_P, d_P, 5);
CUBLASmalloc(n2, d_S, 3);
CUBLASset(n2, h_S, d_S, 3);
// P = P * S (n by N/2)
cublasSgemm('n', 'n', N, N/2, N/2, alpha, d_P, N, d_S, N/2, beta, d_P, N); // [A]_m*k X [B]_k*n --> ('n', 'n', m, n, k, alpha, A, m, B, k, beta, C, m) // is column major
float *tmp;
HOSTmalloc(tmp, np, 3);
int i, j;
cout << "Get Value:" << endl;
CUBLASget(np, tmp, d_P);
for(i=0; i< N; i++){
for(j=0; j< N/2; j++){
int idx = IDX2C(i, j, N);
cout << " " << tmp[idx];
cout << endl;
free(tmp);
CUBLASfree(d_S, 1);
CUBLASfree(d_P, 2);
/* Shutdown */
status = cublasShutdown();
fprintf (stderr, "!!!! shutdown error (A)\n");
return EXIT_SUCCESS;
[/codebox]
And here is my result ( when my LOG_N = 6) ( when LOG_N < 6 is no error)
[codebox]
Get Value:
1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
-1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1
1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16
-1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16
[/codebox]
here is strange about right and down side of the matrix.
when LOG_N = 7;
[codebox]
Get Value:
1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33
-1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -33 -33 -33 -33 -33 -33 -33 -33 -33 -33 -33 -33 -33 -33 -33 -33 -33 -33 -33 -33 -33 -33 -33 -33 -33 -33 -33 -33 -33 -33 -33 -33
1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32
-1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -32 -32 -32 -32 -32 -32 -32 -32 -32 -32 -32 -32 -32 -32 -32 -32 -32 -32 -32 -32 -32 -32 -32 -32 -32 -32 -32 -32 -32 -32 -32 -32
[/codebox]
the right side of the matrix is error.
here is my device intomation
[codebox]
Device 0: “GeForce 9300M G”
CUDA Driver Version: 2.30
CUDA Runtime Version: 2.30
CUDA Capability Major revision number: 1
CUDA Capability Minor revision number: 1
Total amount of global memory: 267714560 bytes
Number of multiprocessors: 2
Number of cores: 16
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 0.80 GHz
Concurrent copy and execution: Yes
Run time limit on kernels: Yes
Integrated: No
Support host page-locked memory mapping: No
Compute mode: Default (multiple host threads can use this device simultaneously)
[/codebox]
Thanks everyone!
