Simple parallel code behaves oddly with concurrent kernels
Hi all,
I am a sort of newbie CUDA programmer. I’ve put my hands at work on a Fermi (2050) card and started experimenting with it.
I came across the concurrent kernel execution part of the programming guide and wanted to see what kind of performance improvements I could get rewriting part of my kernels.
I started from my simplest one, a complex vector to complex vector sum.
The non-concurrent version of my code is as follows:
//kernel
__global__ void
VectorVectorSumKernelCC_O(const float2* aIn1,
						 const float2* aIn2,
						 float2* aOut,
						 const unsigned int aSize) {
  const unsigned int myPos = blockIdx.x * blockDim.x + threadIdx.x;
  if (myPos < aSize) {
	aOut[myPos].x = aIn1[myPos].x + aIn2[myPos].x;
	aOut[myPos].y = aIn1[myPos].y + aIn2[myPos].y;
#define BLOCK_SIZE (1<<9)
//host
__host__ cudaError_t CudaSumVecVecCC_O( const float2* aIn1,
										const float2* aIn2,
										float2* aOut,
	dim3 myThreads(BLOCK_SIZE);
	dim3 myGrid((aSize + BLOCK_SIZE - 1) / BLOCK_SIZE);
	cudaThreadSynchronize();
	VectorVectorSumKernelCC_O<<< myGrid, myThreads>>>(aIn1,
										aIn2,
										aOut,
										aSize);
	return cudaSuccess;
Leaving the kernel code untouched, I chose the following way to deploy concurrent kernels:
template<int N>
class CudaStream {
  public:
  CudaStream() {
	for( int i = 0; i < N; i++) {
	  cudaStreamCreate(&theStream[i]);
  ~CudaStream() {
	  cudaStreamDestroy(theStream[i]);
  cudaStream_t theStream[N];
//host
										const float2* aIn2,
										float2* aOut,
const size_t myNumKernels = (1 << 3);
  static CudaStream<myNumKernels> myStreams;
const size_t myChunkSize = aSize / myNumKernels;
  dim3 myGrid((myChunkSize + BLOCK_SIZE - 1) / BLOCK_SIZE);
int myRealKernNumb = (aSize % myNumKernels != 0) ? myNumKernels + 1 : myNumKernels;
for(int i=0; i<myNumKernels; i++)
	VectorVectorSumKernelCC_O<<<myGrid, myThreads, 0, myStreams.theStream[i]>>>(
	  &aIn1[i*myChunkSize],
	  &aIn2[i*myChunkSize],
	  &aOut[i*myChunkSize],
	  myChunkSize);
  if( aSize % myNumKernels != 0 ) {
	int i = myRealKernNumb - 1;
	  aSize - (i * myChunkSize) );
return cudaSuccess;
Please notice that I have one more kernel invocation in case aSize is not multiple of myNumKernels.
The host function CudaSumVecVecCC_O is iteratively invoked within a performance test, with an increasing vectors’ size from 2^10 to 2^22, with powers of two steps, so the last kernel invocation won’t happen.
I put here the results of these performance tests, so that maybe someone can shed a bit of light upon them.
Non-Concurrent Execution
ADDCC[2^10] -> time:	0.0121729
ADDCC[2^11] -> time:	0.0125819
ADDCC[2^12] -> time:	0.0128622
ADDCC[2^13] -> time:	0.0167381
ADDCC[2^14] -> time:	0.0254805
ADDCC[2^15] -> time:	0.0253569
ADDCC[2^16] -> time:	0.0264088
ADDCC[2^17] -> time:	0.0401843
ADDCC[2^18] -> time:	0.0706934
ADDCC[2^19] -> time:	0.124931
ADDCC[2^20] -> time:	0.233733
ADDCC[2^21] -> time:	0.44601
ADDCC[2^22] -> time:	0.880258
Concurrent Execution, number of kernels: 1
ADDCC[2^10] -> time:	0.0104474
ADDCC[2^11] -> time:	0.0105187
ADDCC[2^12] -> time:	0.0104961
ADDCC[2^13] -> time:	0.0215177
ADDCC[2^14] -> time:	0.0240342
ADDCC[2^15] -> time:	0.0185507
ADDCC[2^16] -> time:	0.0205446
ADDCC[2^17] -> time:	0.0298381
ADDCC[2^18] -> time:	0.0570364
ADDCC[2^19] -> time:	0.111079
ADDCC[2^20] -> time:	0.219384
ADDCC[2^21] -> time:	0.435755
ADDCC[2^22] -> time:	0.86979
Concurrent Execution, number of kernels: 2
ADDCC[2^10] -> time:	0.0145335
ADDCC[2^11] -> time:	0.0145678
ADDCC[2^12] -> time:	0.0143913
ADDCC[2^13] -> time:	0.0145683
ADDCC[2^14] -> time:	0.0335424
ADDCC[2^15] -> time:	0.016053
ADDCC[2^16] -> time:	0.0212547
ADDCC[2^17] -> time:	0.0294669
ADDCC[2^18] -> time:	0.0566485
ADDCC[2^19] -> time:	0.110735
ADDCC[2^20] -> time:	0.219054
ADDCC[2^21] -> time:	0.435459
ADDCC[2^22] -> time:	0.869478
Concurrent Execution, number of kernels: 4
ADDCC[2^10] -> time:	0.0231104
ADDCC[2^11] -> time:	0.0232158
ADDCC[2^12] -> time:	0.0230844
ADDCC[2^13] -> time:	0.0231635
ADDCC[2^14] -> time:	0.0245262
ADDCC[2^15] -> time:	0.0242395
ADDCC[2^16] -> time:	0.0246462
ADDCC[2^17] -> time:	0.0320372
ADDCC[2^18] -> time:	0.0589968
ADDCC[2^19] -> time:	0.113202
ADDCC[2^20] -> time:	0.221437
ADDCC[2^21] -> time:	0.437941
ADDCC[2^22] -> time:	0.872315
Concurrent Execution, number of kernels: 8
ADDCC[2^10] -> time:	0.0390721
ADDCC[2^11] -> time:	0.0393887
ADDCC[2^12] -> time:	0.039282
ADDCC[2^13] -> time:	0.0428878
ADDCC[2^14] -> time:	0.0695331
ADDCC[2^15] -> time:	0.0433453
ADDCC[2^16] -> time:	0.0431187
ADDCC[2^17] -> time:	0.0422312
ADDCC[2^18] -> time:	0.0631554
ADDCC[2^19] -> time:	0.116901
ADDCC[2^20] -> time:	0.225481
ADDCC[2^21] -> time:	0.442002
ADDCC[2^22] -> time:	0.87626
Concurrent Execution, number of kernels: 16
ADDCC[2^10] -> time:	0.0721062
ADDCC[2^11] -> time:	0.0719587
ADDCC[2^12] -> time:	0.071891
ADDCC[2^13] -> time:	0.0730289
ADDCC[2^14] -> time:	0.0721654
ADDCC[2^15] -> time:	0.0731358
ADDCC[2^16] -> time:	0.0736931
ADDCC[2^17] -> time:	0.0755137
ADDCC[2^18] -> time:	0.0731187
ADDCC[2^19] -> time:	0.125743
ADDCC[2^20] -> time:	0.23309
ADDCC[2^21] -> time:	0.449978
ADDCC[2^22] -> time:	0.884631
Things to notice (and to explain, if possible):
    [*] non-concurrent execution and concurrent execution with a 1-sized stream array behave differently;
    [*] smaller cases get worse and worse as the number of concurrent kernel invocations grows;
    [*] medium cases (2^15) have an optimal performance with 1 or 2 kernels, more than that is harmful;
    [*] heaviest cases only get worse if executing concurrently.
Especially the last point leaves me a bit surprised. Is this further parallelization supposed to generally increase performances, by keeping all the processors as busy as possible, isn’it?
Thanks all!
M.
