I’m trying to do simple sum reduction (1, 1, 16) → (1, 1, 1) across last dimension, in order to implement softmax graph with backend API, but engine is not initialized for every configuration
W! CuDNN (v90300 75) function cudnnBackendGetAttribute() called:
w! Info: Traceback contains 24 message(s)
w! Warning: CUDNN_STATUS_NOT_SUPPORTED_LAYOUT; Reason: !is_NHWC
w! Warning: CUDNN_STATUS_NOT_SUPPORTED_LAYOUT; Reason: check_reduction_support_fort(node)
w! Warning: CUDNN_STATUS_NOT_SUPPORTED_LAYOUT; Reason: check_node_support_fort(node_ptr)
w! Warning: CUDNN_STATUS_NOT_SUPPORTED_LAYOUT; Reason: check_for_support()
w! Warning: CUDNN_STATUS_NOT_SUPPORTED; Reason: ptr->isSupported()
w! Warning: CUDNN_STATUS_NOT_SUPPORTED; Reason: finalize_internal()
w! Time: 2024-09-02T15:23:13.208488 (0d+0h+0m+0s since start)
w! Process=9356; Thread=13996; GPU=NULL; Handle=NULL; StreamId=NULL.
I! CuDNN (v90300 75) function cudnnBackendCreateDescriptor() called:
i! descriptorType: type=cudnnBackendDescriptorType_t; val=CUDNN_BACKEND_ENGINE_DESCRIPTOR (2);
i! Time: 2024-09-02T15:23:13.210520 (0d+0h+0m+0s since start)
i! Process=9356; Thread=13996; GPU=NULL; Handle=NULL; StreamId=NULL.
i! status: type=cudnnStatus_t; val=CUDNN_STATUS_SUCCESS (0);
I! CuDNN (v90300 75) function cudnnBackendGetAttribute() called:
i! descriptor: type=CUDNN_BACKEND_ENGINECFG_DESCRIPTOR:
i! engine: type=CUDNN_BACKEND_ENGINE_DESCRIPTOR:
i! opGraph: type=CUDNN_BACKEND_OPERATIONGRAPH_DESCRIPTOR:
i! reductionOp: type=CUDNN_BACKEND_OPERATION_REDUCTION_DESCRIPTOR:
i! xDesc: type=CUDNN_BACKEND_TENSOR_DESCRIPTOR:
i! type: type=cudnnDataType_t; val=CUDNN_DATA_FLOAT (0);
i! nbDims: type=int; val=3;
i! dimA: type=int; val=[1,1,16];
i! strideA: type=int; val=[16,16,1];
i! uid: type=int64_t; val=1;
i! alignmentInBytes: type=int64_t; val=16;
i! isVirtual: type=bool; val=false;
i! isByVal: type=bool; val=false;
i! yDesc: type=CUDNN_BACKEND_TENSOR_DESCRIPTOR:
i! dimA: type=int; val=[1,1,1];
i! strideA: type=int; val=[1,1,1];
i! uid: type=int64_t; val=2;
i! reduceDesc: type=CUDNN_BACKEND_REDUCTION_DESCRIPTOR:
i! mathPrec: type=cudnnDataType_t; val=CUDNN_DATA_FLOAT (0);
i! reduceOp: type=cudnnReduceTensorOp_t; val=CUDNN_REDUCE_TENSOR_ADD (0);
i! engine_id: type=int; val=1;
i! knobDesc: type=cudnnBackendDescriptor_t:
i! CUDNN_KNOB_TYPE_SPLIT_K_SLC: type=int; val=-1;
i! CUDNN_KNOB_TYPE_KERNEL_CFG: type=int; val=10;
i! numericalNotes: type=cudnnBackendDescriptor_t:
i! CUDNN_NUMERICAL_NOTE_TENSOR_CORE: type=bool; val=true;
i! behaviorNotes: type=cudnnBackendDescriptor_t:
i! CUDNN_BEHAVIOR_NOTE_RUNTIME_COMPILATION: type=bool; val=true;
i! attributeName: type=cudnnBackendAttributeName_t; val=CUDNN_ATTR_ENGINECFG_ENGINE (300);
i! attributeType: type=cudnnBackendAttributeType_t; val=CUDNN_TYPE_BACKEND_DESCRIPTOR (15);
i! requestedElementCount: type=int64_t; val=1;
i! elementCount: location=host; addr=000000C954F7E998;
i! arrayOfElements: location=host; addr=000000C954F7E990;
i! Time: 2024-09-02T15:23:13.211530 (0d+0h+0m+0s since start)
i! status: type=cudnnStatus_t; val=CUDNN_STATUS_NOT_INITIALIZED (1001);
i! Time: 2024-09-02T15:23:13.215528 (0d+0h+0m+0s since start)
Full log here: gist:40ade5ff9563ab0cec870519b352a898 · GitHub
